Engine & Oil Pressure Problems 2.9 - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 06-23-2002, 01:47 AM
mikeeep mikeeep is offline
mikeeep is starting off with a positive reputation.
I've got an 89 Bronco II with a 2.9L engine. It cracked a head, and so I went ahead and put two rebuilt heads on the engine. The mechanic told me he changed the lifters, turns out the guy is a compulsive liar and didn't. It started tapping right after getting it back, now it's getting worse, and worse and worse... it sounds at times like it's going to break the rocker arms off!
So, the engine is tapping like crazy now, and I'm afraid that instead of just lifters, it's going to need rocker arms, maybe even a camshaft (if that is possible).
What can I expect in the way of cost, to replace the lifters in this engine?
=ALSO=
Just recently while on a trip I noticed something odd with the oil pressure. It went to zero at idle, and as I rev'd it up, it went back up - so while I was driving it was fine, but then slowing down it would go all the way to zero. When it's cold, it has decent pressure all the time - I can drive probably 20 miles no problem, but as it warms up, it will disappear at idle speeds (like at a red light or stop sign). Any clue what is causing this? Now scare me and tell me the engine has to be lifted to get to what looks like the silliest oil pan design I have ever seen - to replace the oil pump if that is what you guys think it is?
Do you think my first problem (all the clacking) is just due to this goof not replacing the lifters?
Do you think my second problem is the oil pump?
Thanks for your help.
Mike
Old 06-23-2002, 09:12 PM
steve_ steve_ is offline
steve_ is starting off with a positive reputation.
well so i have heard from many people these motors do tick even after a rebuild howvere if its real loud id havce it looked at by someone other than the mechanic that you claim rebuilt it as for the oil pump their are other ways around lifting the motor out
you could in turn drop the suspension and lift the motor up but not out course in my opinion if your going to all that trouble and you cannot verify that the oilpump was replaced in the past 8 million years id replace it
steve
Old 06-24-2002, 08:33 AM
Avanti Avanti is offline
Avanti is starting off with a positive reputation.
Chances are that the crankshaft bearings are worn out due to the antifreeze leaking. Had the same problem in a 89 Bronco II I bought 4 years ago. The heads were cracked and all the antifreeze washed out the bearings. When you pulled up to a stop after running for 10 miles the oil pressure would flip to below normal.So I pulled the engine. Crank had to be reground so I did a total rebuild.
Old 06-24-2002, 09:50 PM
Flat tappet lifter replacement timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 3 10-17-2014 12:57 AM
another pedestal rocker adjustment thread 73 fourxfour 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 38 02-20-2011 03:55 PM
valvetrain tick zaaac 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 01-31-2010 03:55 PM
6.9 lifter problem racesidner Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 03-30-2004 05:07 PM
2.9 lifter tap? Help edward327 Bronco II 12 02-20-2004 06:25 PM
Tags
29, bronco, engine, ford, ii, motor, oil, pressure, problems, pump, specifications
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
