white smoke on startup - Ford Truck Enthusiasts Forums
Old 09-26-2004, 01:02 PM
ceprice ceprice is offline
ceprice is starting off with a positive reputation.
I have a 92 ranger 2.3l 5 speed occasionally on start up it will smoke a lot (up to 3 min) the smoke is white and it does not do it all the time. it seems more frequent now that it is cooling off at night my coolant level is good any ideas on what to check?
thanks
Old 09-26-2004, 05:25 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Are you sure the smoke is white? Blue oil burning smoke looks white to some folks.
White smoke would be coolant resulting in some amount of consumption.
Blue smoke would be oil. How much oil does the engine go through?
AL.
Old 09-26-2004, 09:27 PM
the truck isnt going through much oil, the smoke does have a blue tinge to it but i think it is definately white (mostly) what is weird is that if it stays warm at night it wont smoke. but when it does its solid smoke coming out the exhaust. Would it smoke this much (2-3 min) if it were the valve seals?
Old 09-27-2004, 10:01 PM
Dealford's Avatar
How cold are we talking here? Every vehicle will produce white exhaust smoke until it warms up some. You've seen this during the winter.
How's the thermostat? Does the engine reach normal operating temp. in a timely manor, or does it seem to take forever?
Is your truck a high miler,200k + ?
AL.
Old 09-27-2004, 10:31 PM
temp last night was about 3 degrees it smoked lots this morning but when i left work this afternoon no smoke at all,I am sure it isnt the normal white smoke you see in the winter. thermostat in new , the truck heats up ok and runs great it has 245000 km on it .I dont think its the valve seals due to the amount of smoke but i think I might change the valve seals I have the time and it is best to do before it is too cold out.
Old 09-28-2004, 09:13 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
I had a '94 ranger 4cyl with 278,000 mi on it when I totaled it....it smoked on starts. The amount of smoke depended on how long it sat without running(ie more in morning than after work). We tore down the engine to pull a piston after the wreck to discover bad rings- my friend's '91 4cyl is doing the same now....
Scott
1997 F-250, 7.3 Thick white smoke a start-up Mercniac 1994.5 - 1997 7.3L Power Stroke Diesel 19 11-21-2015 01:05 PM
No start, just cranks and smokes white kbarbee95 1994.5 - 1997 7.3L Power Stroke Diesel 10 10-13-2015 12:11 AM
White Smoke (always) and Black Smoke (most of the time) Please Help - Can't afford a new vehicle nicksorenson 1994.5 - 1997 7.3L Power Stroke Diesel 19 07-05-2013 09:43 AM
6.0 white smoke loss of power rough idle need help dwood3311 6.0L Power Stroke Diesel 16 11-18-2011 10:36 AM
Help..ALOT of smoke. Powerstroke-7.3 1999 - 2003 7.3L Power Stroke Diesel 20 12-09-2009 10:17 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2002, 93, blue, cold, exhaust, f150, f350, ford, great, ranger, runs, smoke, smokes, start, startup, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
