propane kits - Ford Truck Enthusiasts Forums
propane kits
Old 09-26-2004, 01:41 PM
mooney456 mooney456 is offline
mooney456 is starting off with a positive reputation.
propane kits
who all offers propane kits for 6.9L diesel
Thanks
mooney456
Old 09-26-2004, 02:05 PM
Dieseldan7.3's Avatar
Dieseldan7.3 Dieseldan7.3 is offline
Dieseldan7.3 is starting off with a positive reputation.
JC whitney supposedly offers a universal LP kit that hooks a hose straight to your airbox/filter lid. I looked at it on their website and all it includes is a regulator and some hose. YOu have get your own tank and a lot of other parts and they charge you $800 for it! It sucks! I am thinking about getting a regulator and some gas grill parts to rig it to my 7.3 IDI. It should be the same as your 6.9. Horsepower increase is 70+ on a PSD. Not sure for our turboless dinosaurs.
Old 09-26-2004, 02:17 PM
nogo73's Avatar
nogo73 nogo73 is offline
nogo73 is starting off with a positive reputation.
get it all dot approved It may cost but then you don't have to worry about being sued if you get in a reck. check your local propane dealer tell him what you're looking for. If you don't have a turbo you need a "red roster" kit it made to work on farm tractors
Old 09-26-2004, 03:11 PM
can you tell me more about the red roster kit, also where can i pick one up?
Thanks for the info
mooney456
Old 09-26-2004, 10:19 PM
nogo73's Avatar
I'd get a forklift style tank and brackets sounds cheaper and easier to change tanks about $150 and the lay down bracket is $82. I'd do the rest of the system by buying the parts somewhere else but I guess a local lp dealer could set you up pretty well mine told me around 600 total but the system is designed for farm tractor they called a mechanical red roster(acme is the supplier up in Minnesota).look at products at www-Acmecarb-com by the way nobody has a good safe kit as this company. but have soap water on hand to test the lines make sure this doesn't blow up on you after you have it installed propane can be very good if controled or it can be very bad.
Old 09-26-2004, 10:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
The Red Roster kit specifies an electronically injected engine. That leaves the IDI out, but is ideal for the power stroke engine.
Old 09-27-2004, 12:09 PM
la350 la350 is offline
la350 is starting off with a positive reputation.
Numerous vendors sell the Powershot 2000 for around 600-650.00 Huffenberger Restorations in Hanford CA sells it for 599.00 I bought my Hypermax from them. This is best system I've read reviews about for the 6.9/7.3. Its on my Christmas list!!!
Lance
Old 09-27-2004, 12:21 PM
nogo73's Avatar
they don't show the "mechanical red roster" thats the one you want ok
Old 09-30-2004, 10:50 AM
Raceallday Raceallday is offline
Raceallday is starting off with a positive reputation.
How does a propane kit work? Is it like a nitrous kit for a gas engine that only offers short power bursts? Or, is the propane a continous power increase (like a turbo) until the tank is empty?
Old 09-30-2004, 01:16 PM
nogo73's Avatar
Its kind of like Nitrous Oxide for diesels you can have it on for so long but if your exhaust gas temps get to high you have to let off. what it does is add another fuel to the fire that helps every thing burn. If all your fuel is burnt you get more power. Also if you really in to all of this bottle fed stuff you can add Nitrous Oxide too
Old 10-03-2004, 08:07 AM
Turbo Indian Turbo Indian is offline
Turbo Indian is starting off with a positive reputation.
hey yall when I had my 93 idi TD I was thinking about the propane deal but one of the manufactures of it ( I don't remember who) told me it was best to run propane on an intercooled engine, I remember him saying it coud burn a hole in the piston, the intercooler cools the charged air. has anyone ever heard this?
Old 10-03-2004, 08:36 AM
A turbo can melt the pistons as well. That is why you install a pyrometer.
Old 10-05-2004, 06:09 PM
when hooking up the propane cant you just run it to the air filter bowl and not mess with injectors?
Old 10-05-2004, 10:32 PM
Yes you can if you have the right controls to control the flow of propane.
Tags
350, 69l, f250, ford, kit, kits, propane, stacks, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
