4.9 throttle body return spring?
I have searched this forum and cannot find the info I need, so any help would be greatly appreciated.
I parked my 88 f150 4.9 for a while and I started it the other day to move it, and it is idling high, the gas pedal wont return. I inspected the throttle body and came to the conclusion that the return spring? if thats what it is called is broke. Can anyone tell me where I can get a new one? I really need it soon because I'm ready to start running it again. Thanks everyone.
I never had to replace either one, but you have one on the throttle valve itself and one in the cable end, I don't know if the throttle valve assembly spring is a single bought part or not, I do know that the units are expensive new,I would probably hit the salvage yard for a throttle valve assembly, But unhook your cable and check it over also, there is a return compression spring at the engine side of the cable inside the head unit. Broken Wire
jmccracken1214
02-14-2017 08:46 PM
TerrapinMFG
08-01-2016 07:20 PM
aussiecowboy
06-19-2013 08:47 AM
