Clogged heater core? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 09-25-2004, 05:46 PM
Aeropain Aeropain is offline
Aeropain is starting off with a positive reputation.
I let my 88 warm up, but I don't get any heat. Checked the coolant level (when cold of course) and it is ok.
One heater hose gets too hot to touch (like the rad hoses), the other heater hose (the one leading to the pump) stays cold.
I'm thinking I need to disconnect both hoses, connect that cold hose to a garden hose and reverse flush the core.
Any thoughts? War stories?
Old 09-26-2004, 05:17 AM
SgtJoe SgtJoe is offline
SgtJoe is starting off with a positive reputation.
So far I would think you're on track. Is there a valve inline with a heater hose? Check for temp before and after it.
Old 09-26-2004, 03:23 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
BOTH heater core hoses should be hot. If only ONE is hot then the core is probably plugged. If they are both hot then it could be a blend door problem. AeroColorado or someone should be able to help you with that problem. Good luck!
-Matt
Old 09-26-2004, 08:52 PM
Well, I went to the autoparts store and bought 2 5/8" heater hose repair kits (plastic pipe and 2 clamps) then I went to the Home Improvment store and bought a female hose repair fitting.
I cut the heater hoses, and put the female hose fitting on the heater core outlet hose. I then hooked up the garden hose (through a spray nozzle so I'd have control of the flow). Put a 5 gal bucket under the free end of the heater's input hose and turned on the water.
I got a bucket full of gray glop. The former owner had mentioned having the heads redone, so I think that's the culprit. (Yes he was the sort to simply say oh well and have no heat for 3 years)
I cleaned up, and used the repair kits to reconnect the hoses, fired her up, and voila! Heat!
Booya!
Old 09-26-2004, 09:31 PM
psyche psyche is offline
psyche is starting off with a positive reputation.
That's what I call ingenuity!
Old 09-27-2004, 05:52 AM
Beast12's Avatar
Good job! Well worth the time and effort. Better than changing the core out!
-Matt
Old 09-27-2004, 01:00 PM
I'll put that one in my book of tricks. Great thinking and we appreciate the tip!
Old 09-29-2004, 09:41 PM
Glad of it helps someone else.
Just for clarity, the garden hose attaches to the heater hose that leads to the water pump. That way you are reverseing the flow of liquid and pushing whatever is in the way back out the way it came in (and obviosuly could fit through any openings)
Old 10-02-2004, 09:33 PM
cbr900 cbr900 is offline
cbr900 is starting off with a positive reputation.
How about my heater problem, the rear heater works but the front one does not blow hot air, any ideas.
Old 10-02-2004, 09:36 PM
sorry forgot to mention, both the hoses to the heater are getting hot.
Old 10-02-2004, 09:37 PM
Beast12's Avatar
Probably a plugged heater core as well. Feel your heater core hoses and see if they are warm. Could also be a blend door problem.
-Matt
EDIT: You got in just before me. I would guess blend door problem.
Old 10-02-2004, 09:38 PM
heater
now how do I get to this blend door and were about's is it.
Old 10-02-2004, 09:40 PM
Beast12's Avatar
I am not sure about the Aerostar. It is not my "forte". You could do a search on it. http://www.ford-trucks.com/forums/se...earchid=325230
-Matt
Old 10-02-2004, 09:42 PM
yes I guess so thanks anyway beast12.
Heater core conoso 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-18-2016 07:32 AM
heater core or something else? cjben General Automotive Discussion 1 12-08-2015 11:14 PM
'82 150 Heater - Dealer A/C Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 11-29-2015 07:28 PM
No heater...wtf 73 ford guy 1987 - 1996 F150 & Larger F-Series Trucks 78 10-14-2013 12:17 AM
heater blows cold air JP Hobbit 1997 - 2003 F150 5 10-10-2012 07:27 AM
Tags
2001, 2002, aerostar, clogged, core, expedition, f150, fix, ford, heads, heater, heating, plugged, sign, stopped, unclog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
