Rough idol in gear, smooth in park or neutral?
My 86 f-150 5.0L EFI runs smooth in park or idol and is rough when in gear and stopped. It also doesn’t like to start. Or I should say it turns over, starts, idols real ruff (almost like it’s not on all cylinders) then dies out. It starts right back up after and usually settles into a smooth idol. Just looking for some hints as to where to start to trace this problem too… By the way a diagnostic test comes back as fine (11).
Thanks for the suggestions, but the plugs and wires are new...
I went and got the throttle body gasket kit and am going to take it off and do a full clean on it, the IAC and the EGR sometime next week. I also heard of a module on the tranny that could be causing a vacume leak that might be a problem so that is going to get looked at also.
By the way i have the automatic with overdrive on the tranny... Not sure which one... I'll check either on the tag or when i am under it next time....
brent209
01-01-2013 10:55 AM
77429highboy
06-02-2011 09:25 PM
dylanmx
1983 - 2012 Ranger & B-Series
02-28-2009 07:34 PM
fordtrks4fr
23
10-12-2003 08:21 PM
