Passing gear linkage? - Ford Truck Enthusiasts Forums
Old 09-24-2004, 08:07 PM
Mud_Hunter's Avatar
Mud_Hunter Mud_Hunter is offline
Mud_Hunter is starting off with a positive reputation.
What is the official name for the passing gear linkage that goes down to the tranny. ford f100 76 4x4
Old 09-24-2004, 08:11 PM
hdgapeach hdgapeach is offline
hdgapeach is starting off with a positive reputation.
Talking about the "kick down linkage"?
Old 09-24-2004, 08:15 PM
Mud_Hunter's Avatar
yes...thats it ... do u know of a online source for this item?
Old 09-24-2004, 09:00 PM
I'd hop around on some of the sponsor sites on FTE first. If no luck try Bronco Graveyard, LMC, Dennis Carpenter......
I would really be suprised if you don't find one on this site's sponsor list though!
Boneyard would be a good bet too.
Old 09-25-2004, 07:50 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Gary, A salvage yard is probably gonna be the only place to find one, could be wrong. Get one from a pickup and it should work. I would start with the same engine tranny (like 360/C6). You can bend it a little if you need to.
John
Old 09-26-2004, 07:33 AM
tallica2002 tallica2002 is offline
tallica2002 is starting off with a positive reputation.
Since your on the Kickdown issue
I have a 79 150 with a 302 and a c4. When I take off too fast, well actually it doesn't have to be all that fast at all but the whole shifter will pull down and it will stay in 2nd until you pull it back up to drive. I have been told different things I have been told kickdown is out of adjustment, I have been told motor mount, but it does it without the kickdown even hooked up and it has 2 brand new motor mounts. The only thing I can think is the transmission mount what do you guys think?
Old 09-26-2004, 08:07 AM
Mud_Hunter's Avatar
well if your kickdown linkage isnt on and it does it...id say its on the tranny side for sure.
Old 09-26-2004, 12:13 PM
Definitely sounds like engine torque is twisting tranny enough to bump shifter down a gear. If nothing is loose or worn at or around the engine mounts, the tranny mount and cross member would be the next to check. Linkage adjustment might be "on the edge" enough that any torque causes the linkage to down shift. When it's in drive, try just tapping the shifter with a finger or two to see if it feels like it just falls into second. If it does, back off the adjustment enough so that just tapping the shifter doesn't cause it to fall into second.
Old 09-26-2004, 12:37 PM
stangman1 stangman1 is offline
stangman1 is starting off with a positive reputation.
I would check that trans mount first. My old '78 was bad about breaking the rubberin the mount, also check to make sure that the linkage is not hitting the engine or exhast.
Old 09-27-2004, 08:53 AM
Thanks
Thanks for all your help, maybe I can get it right because its becoming a big headache. I will let you know.
'73 runs now but is getting 6 mpg & auto shifts way too fast! bigbeardbiii 1966 - 1977 Early Broncos 10 09-01-2015 04:33 AM
transmission problem - no reverse gravel pit camper 2004 - 2008 F150 1 10-12-2011 10:32 AM
shifter moves freely 78ecf250cs 1997-2006 Expedition & Navigator 5 04-20-2011 06:19 PM
Broken gear shift lever - Auto trans acom01 1987 - 1996 F150 & Larger F-Series Trucks 5 06-24-2010 06:57 AM
need help connecting carburetor chubrock108 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 11-13-2009 09:51 AM
Tags
02, 1966, 1987, adjust, adjustment, c6, f100, f150, ford, gear, linkage, passing, procedure, ranger, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
