Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-24-2004, 07:59 PM
Bubba8573436 is starting off with a positive reputation.
3.0 FFV Spark Plug Question
I have a 1999 ranger 3.0L FFV 2 wheel drive with the automatic. I have read all the posts on what spark plugs to use. I decided to get the motorcraft AGSF12FMF6. My qusetion is the "fine wire" plugs are not double plat and the ignition system in the 3.0L requires DP. Wont the "fine wire" plugs wear out just like the single plat plugs. Another question I have is when I was at the Ford Dealer he gave me AGSF12FM1 instead of the AGSF12FM, what is the difference between the FM and FM1 and can I use the FM1 or should I return them for the FM. I looked up the spark plug coding for motorcraft plugs and FM stands for "finewire Platinum-nickel centerwire electrode, nickel plated shell" and the FM1 stands for "finewire Platinum-nickel centerwire elctrode, nickel plated shell, Special groundwire electrode". Any input would be appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-24-2004, 08:10 PM
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
I was running the AGSF12PP (double platinum), which are hard to find. I talked to a Motorcraft rep. at Sema 2003 last year, to try and find out why Ford was recommending the AGSF22PP as a replacement for the AGSF12PP, which I had tried, and was too HOT. The Motorcraft rep. recommended the AGSF12FMF6, which I am now running, and run very well in my 1999 3.0L FFV. I also talked to a Motorcraft engineer about the "fine wire" platinums, and he said the spark energy was reduced on the "fine wires", and erosion of the GND electrode was not a problem with EDIS.
  #3 (permalink)
Old 09-24-2004, 08:25 PM
Bob
Do you think I can use the FM1 or should I return them and get the FM
thanks for the fast reply
  #4 (permalink)
Old 09-24-2004, 08:35 PM
Sorry, I'm not familiar with the FM or FM1....The P/N on the ones I bought were AGSF12FMF6....good luck!!
  #5 (permalink)
Old 09-25-2004, 12:40 AM
silvapain's Avatar
silvapain is starting off with a positive reputation.
Honestly, it's not really that important to even use DP plugs. I'm using NGK TR6 copper plugs that are 1 heat range colder without problem. The Platimun electrodes are recommended because they last longer - copper actually has a lower resistivity and therefore conducts the spark better.
Unless Ford has changed part numbers, there are actually two different sets of plugs for the Vulcan engine. One bank uses a platinum center electrode, and the other bank uses a platinum side electrode. This is because with the waste-spark EDIS system that the vulcan uses, the polarity of the banks are opposite. Using DP's just makes it easier because you only have to remember one plug number.
Now, if you actually use E85 ethanol in your FFV..... that's beyond my understanding.
__________________
1997 Taurus GL 3.0L Vulcan
  #6 (permalink)
Old 09-25-2004, 01:07 AM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
I've heard and read more than a few accounts about Bosch plugs failing in DIS/EDIS ignitons systems, many times within 20K. And I've heard and read even more about non-OEM plugs in general causing driveability concerns in Fords which went away after re-installing OEM replacement plugs (i.e., Motorcraft or Autolite DPS, and now Motorcraft FM series).
On the other hand, I've never heard or read anything about the OEM replacements causing problems in a DIS/EDIS igntion. So it seems pretty straightforward to me.
FWIW, the factory spark plugs in a DIS/EDIS system do have two different part numbers, depending on the bank of cylinders that they are installed in. But the OEM aftermarket plugs have a single part #.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #7 (permalink)
Old 09-25-2004, 06:47 AM
Quote:
If you calculate the total series resistance, the difference in the resistance component of the electrode (copper vs platinum) is a wash, compared to the
K-OHMS (1000's of OHMS) in the plug wires......So, there will be no performance increase with copper over platinum plugs due to electrode resistance.
  #8 (permalink)
Old 09-26-2004, 07:03 PM
silvapain's Avatar
I know. The formula for resistance is R=p(l/A) where p=resistivity, l=length of wire, and A=cross-sectional area. The resistivity for copper is 1.7x10^-8 while the resistivity of platinum is ~11x10^-8, but with such a small cross-sectional area, the resistance change is negligible. I simply stated it because many people assume that because manufacturers state that platinum plugs are "better", that means that platinum plugs "perform better". Copper also has better thermal conductivity, meaning that it dissipates combustion heat better than platinum.
__________________
  #9 (permalink)
Old 09-26-2004, 08:01 PM
Electrode thermal conduction is taken into consideration when the heat range of the plug is determined. Another reason to use Motorcrafts, they are the correct heat range for a Ford engine.....The main reason for using platinum plugs is longevity.....
  #10 (permalink)
Old 09-26-2004, 08:13 PM
CosmoKramer79 is starting off with a positive reputation.
I have a 2001 3.0 Ranger Edge and need to change the spark plugs. I heard the Autolite DPs were best for them. Should I get those? And should I get any wires with it or just that?
  #11 (permalink)
Old 09-26-2004, 08:18 PM
Quote:
Autolite and Motorcraft spark plugs are both made by Honeywell. I have heard that there are different quality standards between Autolite and Motorcraft, and Motorcraft has the higher standards (I don't know this for sure!!). To be on the safe side, I would go with the Motorcrafts...For plug wires, I have had good luck with the NAPA customs, made by Beldon.
  #12 (permalink)
Old 09-26-2004, 11:50 PM
silvapain's Avatar
Your'e right. I had a brain fart on that one.
If anyone is interested, NGK has an interesting article on spark plugs.
http://www.ngksparkplugs.com/techinf...000&country=US
__________________
  #13 (permalink)
Old 09-27-2004, 08:16 PM
Realgun is starting off with a positive reputation.
I used E-85
The feel of power was good on E-85 mileage was bad. Both Gasoline and E-85. 2003 Supercab 3.0 V6 FFV 5 speed Auto.
I got around town normal driving was 19.7 on gas and 15.9 E-85.
I live at 5000 ft here in Albuquerque. Pulling a 2500LBs boat on E-85 got 13 mpg. Gasoline 10.
Price of E-85 is always .10 more for some reason and only 1 place to buy it. Good thing its 1 block from work. Even though it was a good truck it left a lot to be desired. I had a 1993 Ranger and a 3.0 V6 5 speed manual and always got 25 mpg around town and felt stronger. Me thinks they comprimised the truck to much for e-85.
Traded for an f-150 SCREW. 15.9 mpg around town. Its the same as if I were using E-85 and actually costs less.
This is the 5.4 Litre motor. Power is beautiful.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
