Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-24-2004, 04:49 PM
Toreador_Diesel's Avatar
Toreador_Diesel is gaining momentum as a positive member of FTE.
Post Issues with the Windstar
A dear friend of mine was driving to work about a week ago when his Windstar started giving touble. From what hes told me, it started losing power and eventually it died and wouldn't start;it wouldn't even crank. He called me up to help him so I went out there to lend a hand. At first we thought it was the alternator and/or the battery. So we jump started it and got it running. The SES light was on and stayed on after it was started, so I knew something was definately wrong. While it was running, I looked below the hood and things didn't sound like they should. It could bearly idle and sounded like things were out of sync with each other. With the power loss and what I would describe as a "piston slap", my best guess is that it's the Camshaft Position Sensor. Powerstrokes exhibit the same symptoms, but just to be sure, I'm asking for a little help.
__________________
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
Sonnax/Tricumulator kit
V10 Trans Cooler
Power, Heat, Lighted, Signal TT Mirrors
6 inch PROcomp lift
315/75/16 BFG AT K/Os
9007 Bosch HIDs
4.10 Gears
WW
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-24-2004, 07:50 PM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
You friend has to get the codes pulled. If the SES light is on, then there are codes stored.
Your CMP sensor guess sounds logical, but without the codes, it's still just a guess.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 09-25-2004, 11:10 PM
Post
The van can't/won't move. He tried to have it towed the other day and the wrecker gave up and left it. The steering wheel just won't turn. So guiding it onto a flatbed wrecker wasn't a good idea. Is there some kind of portable code reader or tuner like the Diablo Predator or Superchips Microtuner? Or just a code reader in general?
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
  #4 (permalink)
Old 09-25-2004, 11:44 PM
Rockledge's Avatar
Yes, there are portable hand held codereaders, they plug right into the OBD-II test connector located somewhere underneath the drivers side dash. I have one myself. So there is no need to move the van. Maybe you can rent a code-reader from AutoZone or some place like that.
__________________
Ford Pics
  #5 (permalink)
Old 09-26-2004, 03:20 PM
Thrillseeker is starting off with a positive reputation.
My son has a '94 Ranger w/ a 3.0L.. The engine idles very high.. We have checked the MAF and the TPS and they are fine.. We did have a bad idle control valve so we replaced it.. It does not look exactly like the one we took off, but it has the part number they call for,so we used it and still have the problem we started with.. The engine will not idle down.. We also checked the TFI module..any ideas?? Thanks in advance.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
