2.3 Cold Startup Problem - Ford Truck Enthusiasts Forums
Old 09-23-2004, 11:37 PM
Jimmy0306 Jimmy0306 is offline
Jimmy0306 is starting off with a positive reputation.
When I start my 92 ranger 2.3, it idles really rough....then dies. I can start it right back up and it will run fine all day long. Anyone ever had the same problem? If so, how do i fix it? I have just replaced the plugs, wires, egr valve, egr sensor, air filter, fuel filter, had the injectors cleaned, and a host of other stuff, but the cold start problem remains. It runs like a top after the restart....thank goodness for that.
Old 09-24-2004, 09:53 AM
RangerX's Avatar
RangerX RangerX is offline
RangerX is starting off with a positive reputation.
when i first got my 97 it acted like that, i had to remove an clean the throtlebody. it tool most of the can of cleaner to clean it.. turned out that the idle air valve was cloged with gunk...
Old 09-24-2004, 09:57 AM
Thanks
Ill try the idle air valve. I have no idea where it is or how to clean it, but I'm sure U can find someone to help:-)
Old 09-24-2004, 01:50 PM
RangerX's Avatar
Quote:
Originally Posted by Jimmy0306
Thanks
it's attached to the throtlebody. i had to remove it to get it totaly clean. BE CAREFUL DOING THIS. you can damage it
Old 12-27-2004, 12:33 PM
Ol Rudy Ol Rudy is offline
Ol Rudy is starting off with a positive reputation.
Just removed one from neighbors 96 Ranger for cleaning....watch those two little bolts...likely "stuck" so use WD40 or similiar...anti sieze on reassembly. Valves are $50 new if a good cleaning doesn't do the trick (I used carb cleaner, cue tips, etc.)
Very hard cold start but runs well immediately after op1324 6.0L Power Stroke Diesel 11 02-17-2015 10:45 AM
6.0 with very hard cold start but runs well immediately after op1324 6.0L Power Stroke Diesel 3 02-13-2015 01:20 AM
EGR issue? Nighteyez 4 Cylinder Engines 6 02-08-2008 12:02 PM
help, cold running problem 4dtough 1994.5 - 1997 7.3L Power Stroke Diesel 3 11-20-2007 07:28 AM
Momentary Idle Dip At Startup Critterhunter Ranger & B-Series 6 10-20-2002 12:03 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, cold, ford, start, tricks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
