Fuel pump problems? 1996 f-150 - Ford Truck Enthusiasts Forums
Old 09-23-2004, 06:37 PM
epdc epdc is offline
epdc is starting off with a positive reputation.
Question Fuel pump problems? 1996 f-150
Guys, I need help.
I have a 1996 F-150 XLT, with a bit more than 210,000 miles on it.
I recently swapped out the rear-end and thought I wouldn't be fix'n on it for a while. That hope was short lived. Last about a week ago I am cruising on about half a tank on my rear tank (front tank didn't work when I bought it), I am on the freeway and exit because I see traffic ahead and as I am coasting of the freeway my motor dies. I shift to neutral as to crank the truck up again and nothing (motor just spinning no fire). So then I completely stop turn the key to the off position and then on again and she cranks up but rough, after a few seconds the motor smoothes out and I am on my merry way.
Well I make it about seven blocks down the road and the motor dies again in the middle of the street. So I get under the hood and check all my cables and connects every thing is snug and seems how it ought to be. I push the truck to the side of the street and make some calls to get a tow. After about 15 minutes, and after checking Fuel Pump fuse and relay under hood, I try to crank the truck up again and it starts so I get it off of the main street. As soon as I make the corner the truck dies.
Note - during all the checking and attempts to crank up the truck I am also listening for the fuel pump whine and can't here it (maybe due to traffic). Well I get my dad to pull my truck to a place about 20 minutes away. While he is pulling my truck I attempt to crank it and it still won't start. We get it to the house and I try to turn the engine over while listening for the fuel pump whine. Normally when turning the key to the on position one can here a whine noise coming from the fuel tank, as I do this I can hear no indication that the pump is spinning.
So I thought it was the pump, well I come back to the house two days later to drop the tank and replace the pump. Just for kicks I decide to turn the truck on, and it crank up. So I get out and listen and I can here the pump whining. Then it sputters out, so I try again it takes a sec I can here the pump and it cranks but dies again. So I decide to change the relay. I change the fuel pump relay and I crank it up hear the pump and I let it run for at least 25 minutes. I drive around the block a few times and think its fixed, so I turn the truck off go inside to get ready to go and hop in the truck 15 minutes later and same old story starts again. Turn the key to the on position and get no pump noise, and no crank. 4 days later (TODAY) I hop in the truck and it cranks right up. I want to leave but I don't want to be stuck on the road again.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
By the way I changed the fuel filter less than three months ago (less than 3000 miles).<o></o>
Any Ideas
EPDC
Old 09-23-2004, 07:02 PM
bigredbeast bigredbeast is offline
bigredbeast is starting off with a positive reputation.
what you started to do is the only fix for youre problem. change the pump. what you have is a pump that gets hot becuase the bearings in the pump are wore and make the pump hot and it shuts down. changing the pump is the only solution. i know this only because i have had the same problem a couple of times it comes from youre truck to low of gas cause the only way the pump has to cool is the gas in the tank, if you run it under a quarter tank all the time it will give you this problem. to keep this from happening to youre new pump keep at least a half of a tank in it most of the time.
Old 09-23-2004, 07:06 PM
Robf250 Robf250 is offline
Robf250 is starting off with a positive reputation.
I had a similar problem with my truck, real pain. It would stay running once i got it started but getting it started was a war. Finally just changed the high pressure fuel pump on a guess and it's been fine since. I'd say check the connection between the pump itself and the plastic connector that goes into the harness. Also check the inertia switch, you could try bypassing that. I don't know how the ignition switch works, but with that many miles it might be worn out, causing it to ground the circuit to the pump/ignition at random times.
Rob
Old 09-23-2004, 08:09 PM
Eric C.'s Avatar
Eric C. Eric C. is offline
Eric C. is starting off with a positive reputation.
My Bronco II used to do the same thing till I changed the low pressure pump in the tank (89 old style system). Do the pump and might as well do the front also as this was probably the original problem there to.
Old 09-26-2004, 04:38 PM
Smile Thanks Guys
I checked it all out today, and low and behold it was the electric lines.
Zip Ties & Black Tape
L. S.
EPDC
fuel relay? epdukes13 1987 - 1996 F150 & Larger F-Series Trucks 1 08-12-2014 10:23 AM
'99 Expedition Fuel Pump electrical circuit wagonerkl Expedition & Navigator 22 12-05-2013 09:15 PM
Newbie that Need help with 2 Issues - Tranny ID and Engine Dies Big.Dave 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 10-06-2010 10:23 AM
Seems like a dead battery, but it's not..ERR Stroke'NPower 1999 to 2016 Super Duty 16 12-01-2007 07:27 PM
2003 Expedition not starting k_mowery Expedition & Navigator 11 06-23-2007 02:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
