Anybody compared F1 and F3 spindles
Old 09-23-2004, 02:29 PM
Christopher2's Avatar
Christopher2
Christopher2 is offline
My service maual shows they are the same part. The kits for the front disk conversion all say they are for an F1. I am going to be doing the comparison but could save time if someone already knows the differnce
Old 09-23-2004, 05:11 PM
51dueller's Avatar
51dueller
51dueller is offline
They are the same. I have F-1 hubs on M-3 spindles. They just say F-1 because they only come in a 5 bolt pattern.
Old 09-23-2004, 05:38 PM
Christopher2
Good, the kit is in the mail went out fedex today. Otherwise I was going to put the F1 front end under the truck.
Old 09-23-2004, 05:53 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
What do you want for the F3 hubs?
Old 09-23-2004, 06:05 PM
Christopher2
Talking
Assuming all goes well I would trade you for some knowledge and a welding lesson. I am getting the 8.8 rearend and the spring perches and would like some help getting the rear end welded in and making sure I have the angles correct. I will supply the welder and gas.
Besides I already owe you for the transmission lesson. I put the pin in the transmisison, now the shifter does not spin in circles. When I unscrewed and removed the shifter I found allot of rust that is why I could not get the rest of the gears to work. Sprayed everything down with penetrating oil and now 3rd and 4th work. Hopefully reverse will work loose when I get her moving on her own power.
Old 09-23-2004, 06:11 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
Sounds like a deal to me
F-1 5288
New Member Introductions
03-25-2016 02:11 PM
48 Steel
09-27-2015 12:42 PM
rbr658
07-15-2015 11:34 AM
haven56
09-29-2014 11:45 AM
05-08-2002 09:40 PM
Quick Reply: Anybody compared F1 and F3 spindles
