You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Help. I have a 72 cab that I want to fit to a 78 chassis. I need some info on wiring the "sports style" dash (mainly the ammeter). I am also after some parts, so if anyone knows where in Australia I can find some bits, please let me know.
G'day to a fellow Aussie...
Where do you live?
There are some good places in Queensland if you live anywhere near there, or there are couple of wreckers in Melbourne I know of...
Check out the yellow pages
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
G'day donracing69,
Where did you find your "sports style" dash?
I was thinking of building a new instrument cluster with aftermarket gauges as I havn't been able to find a factory full instrument dash to suit my '79.
Would rather buy a cluster than build one as I have several other projects on the go.
Sorry to reply to a pretty well dead post but the full instrument dash froma TC or TD Cortina slots straight into the 75-79 dash, just need to recalibrate the tacho for the V8(if you have one) and run the appropriate wires and change the senders to suit, did the whole conversion for $120 into a 78 F100 but it was a six so didn't need the tacho recal, this would cost $50 or so from aninstrument specialist.
__________________
The right side is the RIGHT side for the steering wheel.
If anyone needs any parts I have them. I'm located in Melbourne and will post them across Australia. Parts are to suit f100-f350 from 1973-1979. Good doors , bonnets, XLT trim , lights , dash inserts and clusters etc. I'm not a wrecker I'm an enthusias. Call 0401 570 341 or (03) 9337 8778
G'day you blokes.
Yep....I agree. The Cortina TD type tacho gauge cluster is a bolt in deal. The Tacho function has a "trim pot" so all you have to do is turn it one way or the other to calibrate it against a known good tacho. Simple as that.
The only problem I found with the Cortina Gauge cluster is some of the warning lights don't match the original F100-350 cluster. Also you need to run an extra wire for the tacho. Don't forget to use the Cortina type Oil Pressure sensor as the regular Ford F series type didn't work in our '75 F100.
