Help! ecu trouble - Ford Truck Enthusiasts Forums
Help! ecu trouble
Old 09-22-2004, 10:40 PM
calimustang7 calimustang7 is offline
calimustang7 is starting off with a positive reputation.
Exclamation Help! ecu trouble
my 97 2.3L manual ranger just died on me the other day. luckly i was in front of a repair shop that i've visited before. they said it was the ecu. So, I got another one now the truck will start but i wont stay on for more than a sec. i replaced the fuel filter. the truck will run if i give it gas and after its warmed up for a bit it will stay on a little longer before it dies out again then i can restart it and as long as i push the gas pedal a little bit it will stay on please help. thanks
Old 09-23-2004, 12:10 AM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
Have the codes read.
Does it smell like it's getting way too much gas? Pull the vacuum line off the fuel pressure regulator to see if there's gas in the line.
AL.
Old 09-23-2004, 01:00 AM
Lightbulb had code read
the code was P0102 which is MAF or VAF circut low input. The guy at autozone said i should take it to the electrical shope to find out which one it is
Old 09-23-2004, 01:01 AM
Smile
Thank you for your help. I am trying to get my truck up and running because I am a poor college student.
EEC interchange stevetford 1987 - 1996 F150 & Larger F-Series Trucks 12 12-05-2012 09:09 PM
Drive By Wire PrinceValium 2009 - 2014 F150 10 12-05-2012 08:49 PM
1994 351w efi Bandit26 1987 - 1996 F150 & Larger F-Series Trucks 1 06-07-2012 05:17 AM
ECU Chip? 2008f250superduty 1999 to 2016 Super Duty 2 07-25-2011 07:27 PM
2002 Ranger, Hard Start when cold Rex-a-FORD Ranger & B-Series 7 03-11-2003 10:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
ford, p0102, running, stay, v10, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
