Tight oxygen sensor
Tight oxygen sensor
Any good tricks to remove the sensor from a 99 Ranger manifold (4cyl)? The manifold was replace 40K miles ago and I'm not sure they applied anti-seize. I've already tried the propper socket, on a hot or cold engine.
Does PB Blaster really absorb deep enough to be helpful?
I hate to use a breaker bar and risk breaking something.
Thanks,
Art
Thanks,
Art
I've used Kano Kroil successfully for more than 30 years, in my optics lab, on some mighty bound up things, including military equipt.
I gave some to our Maintenance guys one day back in 85 & they loosened galled stainless bolts on a vacuum system that they previously had to saw/cut or torch to remove.
You can get it in a aerosol can, plain, or with addtives like moly, graphite, or silicone (don't use the silicone loaded Kroil around your engine) at most industrial supply houses. I've seen it at Dixie Bearing, around here.
Is it worth going to the trouble to find, I think so & so does Steve!!!!!
It's not cheep, but it's GOOD!!!! IMHO
A little goes a long way.
Let us know how you get her out.
You can check out their "Maintenance Ideas" or even order it at http://www.kanolabs.com
if the O2 sensor is going to be replaced (and you won't need it anymore) I would suggest Dry Ice. If you warm the Manifold (not to driving Temp, just a little warmer than confortable with your bare hands) then with gloves hold a piece of dry ice to the O2 Sensor, closer to the treads the better--without touching the manifold...the heat will expand the treads on the manifold, and the dry ice will contract the threads on the O2 sensor. This worked for me when I couldn't get mine free either...anti-seize is fairly cheap and one of my best friends!
JSTJ704
07-23-2014 07:44 PM
Raxid
06-20-2009 08:29 AM
