1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
bed bolts
Old 09-22-2004, 06:05 AM
04superduty's Avatar
04superduty
04superduty is offline
bed bolts
does anyone know what size torx bit or whatever for the bed bolts. i need to put in a roll in liner and need to remove the bolts.
Old 09-22-2004, 09:59 PM
WeWeld's Avatar
WeWeld
WeWeld is offline
T55
Gene
Old 09-23-2004, 04:12 AM
V10man's Avatar
V10man
V10man is offline
Something like Herculiner?? I'd just tape over the bolts. I'd personally avoid the do it yourself liners. My Herculiner is too thin to take any abuse.
Old 09-23-2004, 08:52 AM
rmilchman's Avatar
rmilchman
rmilchman is offline
Agreed, my Herculiner is junk. I bought a rustoleam product (2 part) still thin, but better the Herculiner.
Old 09-23-2004, 05:13 PM
04superduty
thanks for the info guys. need to put something down and dont want to spend 500 on a spray in liner.
Old 09-23-2004, 07:46 PM
rmilchman's Avatar
rmilchman
If you feel you have to do it yourself, pick a 2 part product instead of the herculiner.
Old 09-23-2004, 10:36 PM
huntercgr's Avatar
huntercgr
huntercgr is offline
I had Line-X put in mine for 360. Shop around, ask for a 10% discount. Line-X also has a coupon on their web site. It'll outlast you, and look great. Your diy kits won't last.
Old 09-24-2004, 12:11 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Powerstrokedlariat is offline
I had a Rhino liner installed in my long bed for $299 on special. My brother put in one of those do it yourself ones and it has almost all worn off within 1 year. Shop around, good luck!
Old 09-24-2004, 09:42 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Good luck with the bolts I had to grind mine off to get the bed off.
Old 09-24-2004, 08:27 PM
04superduty
i am hoping i will not half to grind the bolts off to get them out. to install the 5th wheel hitch i want they will need to raise my bed up about 2 inches or so. for 300 i will get the spray in liner, thats 200 or so more thay the DIY but worth it.
Old 09-25-2004, 01:51 PM
Rancha9's Avatar
Rancha9
Rancha9 is offline
Ford was nice enough to use a LOT of Lock-tite on the bed and cab mounting bolts... use the right size torx socket, 1/2 inch drive everything, and don't be a wuss, and they'll come out. When I did the body lift on my Ranger, I made sure to put the same generous amount of Lock-tite back on so the subsequent owner could have as much fun as I did...
Built_Ford_Tough_757
17
02-25-2015 06:15 PM
NNf000
1983 - 2012 Ranger & B-Series
04-30-2009 05:38 PM
quaddriver
12-09-2008 11:58 AM
VQ2Fast4U
10-19-2007 12:45 PM
Quick Reply: bed bolts
