hey guys,
i just wanted to get some input from yall and see what you thought about propane injection on a psd. Im thinking about doing it sometime in the future and would like yall to give some pros and cons about the system. if some of you already have propane i would like to hear if yall are impressed with it or not.
I've had the Powershot2000 system on my truck for over a year, and am impressed with the amount of additional power it provides. The installation is relatively easy, once you determine the tank size/location, etc. There's a true 80hp increase on a dyno. The cost of propane itself is well under $.01/mile, so the expense of operation isn't too bad.
The downside is if you have it set too high. Serious damage can occur if safe limits are exceeded. Bent rods and cracked pistons are a few of the potential dangers.
If you decide to install a system, let me know, and I can walk you through the initial "dial in" procedures.
__________________
'95 F-350XLT Crew Cab SRW 4X4 PSD. Intake, exhaust, chip, propane, 1.0AR turbine housing, and then some.
Yea, listen to quadzilla, he knows what he's talking about. If you want to add any other mods to your truck, quadzilla has done it and can tell you how to do it! Just look at his truck in his gallery!!
__________________
ADAM
Early '99 F350 Lariat PSD 4x4 Off Road
Intake, 4" exhaust,Wildman tunes, BWD tranny, Firestone air bags, 60 gal fuel tank/tool box
6/21/08 on a Dynojet:
326.56 HP / 736.66 TQ
Alcohol Tobacco & Firearms ...should be a convenvience store, not a government agency.
I've looked and never been able to see Quadzilla's truck. All I get is this little square with a red dot in the middle.
__________________
Dan
Our greatest priviledge is to enjoy God's Presence
Thank you very much for your input guys.
I will probably get propane injection after i get injectors and sell my edge products, and get a chip that will work with the injectors.
Just so you'll know what to expect..... If you add propane injection to a truck with stock injectors, you get a big increase in power. After adding aftermarket injectors, the amount of incremental power from propane is lower. Most of the people I know see injectors and propane as an either/or proposition. Few run both, though it's been done.
__________________
Thanks again,
Ford Power
Before you invest in another chip find out if yours can simply be reprogrammed. Save a few $$$
__________________
1996 F250 4X4 Crew Cab: Diablo Flip Chip, Powershot 2000, Hypermax exhaust turbo back, Tymar AIS, All the gauges, Bilstein Shocks, AirLift Super Duty bags on the rear
From Quadzilla: "If you decide to install a system, let me know, and I can walk you through the initial "dial in" procedures."
I have driven ford diesel trucks since 1983 and made many modifications on them. I have never used a propane injection yet. Due to my business, I tow RV's very long distances. I have a 4" exhaust, cold air intake system (K&N), Superchip Trimode Tuner and a full gauge system on a 1996 F250 4x4. My mileage is only 12 mpg towing and 15-18 mpg empty (automatic, 3:55 gears). I have access to a complete used Bully Dog system for a 7.3 PS. Would this be a good addition to my towing package?
