E350 Heater core replacement - Ford Truck Enthusiasts Forums
Old 09-22-2004, 01:11 AM
Rebus Rebus is offline
Rebus is starting off with a positive reputation.
Question E350 Heater core replacement
Can anyone tell me how to replace a leaky heater core in a 1989 Ford E350 460CI with A/C?
Old 09-22-2004, 09:05 AM
jtmerritt jtmerritt is offline
jtmerritt is starting off with a positive reputation.
Not positive about an 1989 but I believe you will need to discharge the A/C system and disconnect all the lines going into the A/C and Heater core box mounted in the engine compartment. The A/C and heater core box and blower plenum under the dash are bolted together through the firewall. You remove the bolts and the two parts separate giving you access to the heater core and A/C evaporator. Go on the internet or e-bay and get yourself a service CD for that vehicle. I get them for about $10.
John
Old 09-24-2004, 09:04 AM
hanno2s hanno2s is offline
hanno2s is starting off with a positive reputation.
On my 88 (with AC) it was a simple remove and replace... Remove cover under right side of dash, drop computer down if necessary. Remove heater box cover bolts (various extensions needed). You have now found the heater core. From engine side, unclip the two heater hoses. Now remove core from inside the van. Reverse to install. If using a new gasket around the core, it can be a bear to push back in. Suggest new o-rings on the snap connectors. It didn't involve any part of the A/C system.
Old 09-30-2004, 03:02 AM
vanj vanj is offline
vanj is starting off with a positive reputation.
Because of all the helpful information from the folks here,
I Replaced my heater core on my 88 F150 last weekend.
Went thru the glove box.
Took off the cover plate.
Drained the antifreeze in buckets, engine cold.
Loosed clamps. Two of the clamps were stock, it was a bear to get off.
Cut off hoses, (I replaced with new ones).
Pulled the heater core out, replaced with new one.
Took me a verrrrrrrrrry long time to do this first time project.
Old Besty is up and running again.
Cindy
Heater Core Inlet & Outlet: Which is which? OSHS 1968-2013 Full Size Vans 13 06-19-2014 06:56 AM
how to replace a heater core in a 1998 F 150 brandon olson 1997 - 2003 F150 13 12-30-2013 09:02 AM
1988 heater core replacement f-350 case310350 1987 - 1996 F150 & Larger F-Series Trucks 9 05-09-2012 12:48 AM
Heater Core Size Issue Mudman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-25-2007 06:08 AM
E250 Heater Core Fittings - How to remove? sds357 1987 - 1996 F150 & Larger F-Series Trucks 2 09-29-2003 07:08 AM
Tags
1990, 1997, 2003, 89, 92, 95, box, coil, core, diesel, e350, ford, heater, removal, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
