Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 09-21-2004, 10:49 PM
16secondP71 16secondP71 is offline
Garage is empty, add now
16secondP71 is starting off with a positive reputation.
Ever seen a pinion go through the housing of a Dana 60?... I have!
Well,, I went up to Silver Lake for the last time this year and manged to destroy the front axle in my SD. I launched it over a hill and when the front wheels hit the ground, the driveshaft spun the pinon into two pieces. The worst part is that the ring gear grabbed the broken pinon and pushed it through the top of the diff housing... Can that be welded???
I figure if I can find a weld shop that can weld cast then I can throw a new set of gears in it and have it fixed. Otherwise, I'm off to the late model bone yard in search of a front axle.
__________________
'99 F-250
-PSD
-6 pos. TS performance chip
-Paul's High Performance "Quickie Throttle"
-8.5 inch Pro-Comp lift
-37 X 13.5 Mickey Thompson Baja Claw radial tires
  #2 (permalink)
Old 09-27-2004, 07:47 AM
jalampi jalampi is offline
jalampi is starting off with a positive reputation.
got any pictures?
  #3 (permalink)
Old 09-27-2004, 06:41 PM
NOPE... and probably never will.
__________________
'99 F-250
-PSD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
