3" body lift, will it be enough for 31" tires? - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 09-21-2004, 07:27 PM
origin4200 origin4200 is offline
origin4200 is starting off with a positive reputation.
I have an 88 bronco ii xlt and bought 31" tires on 10.5 rims and need to know if a 3" body lift would be enough to put these tires on without having a rub problem? also i was wandering if anyone has put a body lift on there bronco ii and if it is possible to do myself instead of paying someone so much money for them to do it and if anyone could help me out with know what all the parts on the lift go to
Old 09-22-2004, 01:08 AM
RomerB2's Avatar
RomerB2 RomerB2 is offline
RomerB2 is gaining momentum as a positive member of FTE.
a 3" body lift should get you covered, as long as you dont do any flying through the air stunts while offroading, personally i would go with say a 6" lift suspension, or double 3" with a 3" body, and 3" suspension, i have 265 75 15's on mine which measure out to 30.5" x 10.5 wide, w/ 15" rim, and i don't have a lift at all (soon to get one), but i dont rub at when turning hard, and i've never had tire hit any body parts, so the 3" body should do you good, if you want to know what it looks like w/ no lift you can look at my gallery, and i have a few pics on there.
Old 09-22-2004, 01:11 AM
RomerB2's Avatar
forgot to add.. you can do a body lift yourself, broncoii.org has some directions for a body lift, you can also look at the 4x4 and offroad forum on here and do a search, you should be able to come up with other resources also, i think for a body lift they're mostly nut and bolt, nothing special but i do recomend getting polyurethane to replace all the stock rubber bushings, makes ride a lot better.
Old 09-22-2004, 01:41 AM
Smile
romerb2 thx for the help the web page you gave me was alot of help, im glad you let me know you have helped me out alot.
Old 09-22-2004, 11:13 PM
onestrangebroncoII's Avatar
onestrangebroncoII onestrangebroncoII is offline
onestrangebroncoII is starting off with a positive reputation.
i have 4 inch b lift and stock springs with off road shocks and i run 33x12.50 x15 with just a minor trim on my fenders....on my 86 b2 works great!!! and cheap
Old 09-23-2004, 12:42 AM
RomerB2's Avatar
Your welcome origin4200
onestrangebroncoII - is 4" b lift legal? i've never seen them sold..
Bronco with 1" or 2" body lift kellar 1978 - 1996 Big Bronco 8 11-28-2007 05:18 PM
Homemade 2wd Ranger lift BlueOvalDrifter88 Offroad & 4x4 4 10-12-2005 01:10 AM
whats the biggest tires i can fit with a 3" body lift? tonyevans69 Ranger & B-Series 4 03-06-2002 04:29 PM
Suspension Lift for a bronco II with a CV joint driveshaft nickc84 Bronco II 2 08-20-2001 11:42 PM
Bronco Lifts grifter0 1978 - 1996 Big Bronco 7 10-08-2000 10:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
