dennis carpenter cab mounts - Ford Truck Enthusiasts Forums
Old 09-21-2004, 05:03 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
Has anyone used dennis carpenter cab mounts. I was looking in their catalog, and they have a drawing of their replacement cab mounts. Their people say their mounts are as close to orginals without having the factory stampings. but they dont seem to have an actual picture of thier parts...
Old 09-22-2004, 11:35 PM
Highboy70's Avatar
Highboy70 Highboy70 is offline
Highboy70 is starting off with a positive reputation.
They are excellent! I put in a pair, the only thing was the right side has a hole just like the e brake cable hole on the left side. All I did was plug it. The fit was good and the steel was much thicker than other mounts I've seen. I drilled out all the spot welds in the old ones, I went all the way through the cab floor as well. Then after cleaning it, I put the new cab mount in place and then used the holes in the floor board to weld the new mount in from inside the cab. Much easier this way. Don't drill your mount bolt holes until the cab is dropped down on the new mounts(bushing in place also) do that from the bottom.
It's not that hard to do, use a wire feed welder for best results.
Dennis carpenter cab corners chad77 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 11-17-2015 02:41 AM
Cab Rubbers jamhh 1957 - 1960 F100 & Larger F-Series Trucks 3 02-07-2015 12:03 AM
Best place to buy cab mounts cghstrojan08 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-05-2015 01:02 AM
Dennis Carpenter Coupon Code? johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 0 12-24-2014 09:42 AM
Front Cab Mounts (sheet metal) for 64 F250 1964FORDTUF 1961 - 1966 F-100 & Larger F-Series Trucks 3 03-03-2014 01:19 PM
Tags
cab, cable, cabs, carpentar, carpenter, catalogue, dennis, drilling, ford, hole, mount, mounts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
