Go Back   Ford Truck Enthusiasts Forums > Bronco > 1966 - 1977 Early Broncos
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1966 - 1977 Early Broncos SPONSORED BY:
  #1 (permalink)
Old 09-21-2004, 11:33 AM
Gangly Gangly is offline
Garage is empty, add now
Gangly is starting off with a positive reputation.
Factory Fuel Tank Skid Plate?
I was looking under the 68' Bronco and noticed that there is a skid plate looking mechanism covering the gas tank. It is pretty worn but it looks like a factory piece. Am I under the correct assumption? Was this an option from the factory or is it an aftermarket bolt-on? If it was from the factory, does anybody know what the option code is or if it was standard? Any help would be greatly appreciated!
  #2 (permalink)
Old 09-24-2004, 04:16 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
The fuel tank skid plates were an option in early models. It later came as a package with fuel tank and transfer case skidplates.
Jason
__________________
'12 Dodge 3500 crewcab 6.7 HO, Not Stock!!
'93 F350 CC 4wd 7.3 ZF and a ton of miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
Honey badger don't care...
  #3 (permalink)
Old 06-20-2009, 11:49 AM
play400 play400 is offline
play400 is new and has a neutral reputation at this point.
I have a rear skid pan. Can't remember if it is from the 67 or 75.
  #4 (permalink)
Old 06-28-2009, 07:10 PM
madrockwyo's Avatar
madrockwyo madrockwyo is offline
madrockwyo is starting off with a positive reputation.
67
most likely from the 67. My 67 has a factory skid plate that covers the back half of the tank, but I once hut a rock slightly in front of the skid plate and poked a hole in the tank I made a skid plate out of 1/8" plate and attached it in fromt of and slightly overlapping the factory skid for total protection.
__________________
Scott
1979, F250 4x4 400/C6 reg cab XLT Ranger Chrome Yellow/ White
2001 F150 Super Crew 4x4 V8/auto
1979 F150 4x4 351m/manual parts truck; 1963 Ranchero rolling chassis
1967 Bronco wagon 4x4 289/3 on tree
1961 and 1963 Ford Falcon Rancheros 170/3 on tree
Tags
150, 1978, 2007, 2009, 66, 77, bronco, f150, ford, fuel, gas, plate, plates, skid, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
