Western Snow Plow - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Western Snow Plow
Old 09-20-2004, 08:04 PM
ultraclassic ultraclassic is offline
ultraclassic is starting off with a positive reputation.
Western Snow Plow
A friend of mine got a new western snow plow 7'6"standard w/ quick mount system including lights and joystick control
He got the plow encluded with the truck (03 f250 diesel standard cab)
He want to sell I want to buy.
He doesn't know what it is worth
Could someone tell me what this plow sells for new?
Old 09-20-2004, 08:13 PM
1956MarkII 1956MarkII is offline
1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.
Brand new? I'd have to pay my local supplier about $3500 for that, installed.
Old 09-20-2004, 08:19 PM
Thanks. I wonder what the labor cost of installing it would be.
We plan to just take his mount and wiring from his truck and mount it on my truck with the help of a six pack or two
Old 09-20-2004, 09:16 PM
Bordaine's Avatar
Bordaine Bordaine is offline
Bordaine is starting off with a positive reputation.
On a new install, there is about 6/8 hour labor. The main part of the plow is about 1/2 the install time. To swap from one truck to another, with both trucks there, about 6 hours. It is not that hard of an install. If you have ever do a lift kit you are more that qualified. Please note there is a lift mount frame change for the 04s. There is also another lift mount change for the 05s. You can get instructions from Westerns web site. If you have any problems, please feel free to Email or PM me if you run into any problems.
7 1/2' std plow is a light plow for a SD. You can put up to an 8 1/2' Pro Plow on that truck. As long as you are puting the plow on to do your driveway and a couple of others, no problems. If you plan to do hours of plowing every storm buy at least a 7 1/2' Pro Plow. Also take a look at Westerns web site, Look at the Pro Plow Plus. It all depends on what you plan to do with it.
An almost new 7.5' Std Western plow ???? $2500.00 Only in my opinion. No standard problems to look for. Make sure to change the plow fluid every fall.
Have fun playing in the snow.
Old 09-20-2004, 09:20 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Quote:
I know I do! Check out my gallery for a pic of my plow truck!
-Matt
Old 09-20-2004, 09:28 PM
Bordaine's Avatar
I cant believe its already time to start the whole plow season thing again.
I swear I am moving to Florida.
OK maybe Florida is not a good idea
Old 09-20-2004, 09:40 PM
Beast12's Avatar
I know! My dad (the boss) is getting ready to send out his plowing contracts soon! Soon the snow will be flying! <img src='http://smileys.smileycentral.com/cat/16/16_6_20.gif' border=0></a>
-Matt
Old 09-21-2004, 07:06 AM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
Yeah that plow is to light for and F-250, not really wide enough either,,well its better then a shovel,, but you may end up bending or breaking things ,on it,,,its made for a 1/2 ton truck or Bronco/Blazer size !
I push a 9' Fisher MM on my F-350, sags maybe 3/4 of an inch when I lift it,,and it is like 900 lbs,,, up to you !!
Later,,,,,,,,,,,Mark
Old 09-21-2004, 11:05 AM
dougger222 dougger222 is offline
dougger222 is gaining momentum as a positive member of FTE.dougger222 is gaining momentum as a positive member of FTE.
I bought a two year old Western 8.5 Pro Plow with back drag and a new blade which is so large and heavy duty the back drag blade no longer touches the ground. I paid $1700 for the complete unit plus $80 for the mounting hardware from Western. A budy and I did the install in an afternoon.
Old 09-21-2004, 08:52 PM
I am not looking into going into business with it. Just for clearing mine and maybe a few other driveways. We get snow here on occassion(maryland) but not like up north. We do get hit every couple of years with a 22 inch or better snowfall. Most snowfalls are under 4 inches at a time and sometimes weeks in between. We get a lot of 40 degree plus days in Jan and Feb, So i really dont need a work horse of a plow.
Would this plow fit the bill for my needs or is it too much plow or too little
I have been thinking of offering him $1,000 Firm for the plow and his help in switching it from his truck to mine. Am I out of line with that?
One more thing.. His truck has a front shock type steering stabilizer mounted on a frame tab and the sway bar... I have that tab and sway bar but no stabilizer. Is this required/recomended for the plow hook up
Old 09-21-2004, 08:58 PM
Bordaine's Avatar
If you are just going to do your driveway and a few others, that is a perfect plow for you. As long as your driveway is not 2 miles long.
If you can get it for $1000. that would be a great deal. You can always add a steering stabilizer.
Old 09-21-2004, 09:34 PM
Yeti's Avatar
Yeti Yeti is offline
Yeti is starting off with a positive reputation.
Not to high jack the thread....(like I have never done that before) but...
I got a nice Western uni mount frame that I custom fabricated for a SD with a 8" suspension lift sitting here needing a new home......if ya know anybody...
Old 09-21-2004, 11:32 PM
SMiller SMiller is offline
SMiller is new and has a neutral reputation at this point.
I can't believe someone would think that it would take more then 2 hours max to swap plows from one truck to another, to install a 8ft pro plow on the bosses wifes SD it toke 1:15min, that was our first time and it was no big deal. $2000 to $2650 sounds about right for the plow, all depends how beat up it is. It usilly costs around $250 to $350 to have one installed, price would stay about the same to swap, not allot of work...
snow plows meborder 1997-2006 Expedition & Navigator 4 11-26-2016 07:37 PM
Brackets for mounting snow plow? Sondre Næss Excursion - King of SUVs 3 07-19-2016 10:23 AM
Western Snow Plow Plumberdude3 1999 to 2016 Super Duty 2 04-04-2015 06:54 AM
snow plow retrofit cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 32 01-08-2014 12:36 PM
Anyone successfully modified a new Western ultramount snow plow mount to a highboy? Welsch69 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-27-2011 06:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
