'88 Ford Bronco II - Power loss after warming up - Page 2 - Ford Truck Enthusiasts Forums
Old 09-25-2004, 12:50 AM
onesonny onesonny is offline
onesonny is starting off with a positive reputation.
88 Ford Bronco II - Power loss after warming up.
I am sure you have checked this out but just in case. 88 Bronco II has two fuel pumps. One high volume in the tank and a high pressure in the frame below the drivers door. Just ahead of it there is a large fuel filter mounted in the frame approximately in line with the fire wall. A partially plugged fuel filter will give you good pressure readings at idle or not under load. On the highway under load the fuel volume requirement goes up and will robb the power & almost act like a governor. Good luck!
Old 09-25-2004, 12:02 PM
Bakedbricks Bakedbricks is offline
Bakedbricks is starting off with a positive reputation.
Yup, i have already replaced the filter, which wasn't clogged. The gas tank is also new so it doesn't have junk in it.
Old 09-25-2004, 11:11 PM
dsecurman1 dsecurman1 is offline
dsecurman1 is starting off with a positive reputation.
try this
hello,i had these same problems but what i found out was in neutral under no load i would get good fuel pressure of 30 to 45lbs but if i put it wide open it would briefly jump up to about 4500 to 5000 rpm and surge at around 3000 rpm and the my fuel pressur was only about 28 29lbs which a few pounds is all it takes to cause problems,so i changed the fuel pump and now it runs better than in a year and also note i had these problems also only when it got warm,but if it is a pump i wouldnt know which one i mine only has one in the tank....hope this helps d.
Old 10-01-2004, 01:40 AM
funnyfarmman funnyfarmman is offline
funnyfarmman is starting off with a positive reputation.
Someone please solve this problem! I have the same problem on an 87 Bronco II with the 2.9, and it is driving me insane. I have done all the stuff mentioned here, and more. It runs great for about 2 miles, then has the same symptoms.
I will continue to watch this thread for help!!!
Old 10-01-2004, 09:26 AM
Catfish369's Avatar
Catfish369 Catfish369 is offline
Catfish369 is starting off with a positive reputation.
My '89 B2 was having all kinds of troubles.......stalling, sputtering, weird shifting, backfiring, and no power at all. After pulling codes and taking care of everything I finally found the TPS to be the main problem.
Old 10-01-2004, 11:25 AM
I have swappped TPS, EGR, MAP, IAT, computer, you name I have swapped it. I am going to change the oil pump before I try anything else. I know the sending units were not to good on these engines, so I ignored the flickering oil lite, which was begining to stay on all the time. I changed the sender, only to find the lite still on, so I put a gauge on it, and it doesn't even lift the needle off zero. I started it with the line open and it does pump oil, but not enough to keep me from putting the line back on and starting the nut with one hand. In theory, I wonder if the pressure is so low the lifters won't pump up, and that is part of the problem. I have a steady backfire you can feel with your hand on the air filter box. With brand new heads I shouldn't get anything coming back past an intake valve into the intake manifold unless a valve is stuck open, but I am running 180 psi on all 6 cylinders when I check compression.
I hope I have not damaged the bearings with the low oil pressure. I had no valve clatter that would indicate I really had low pressure.
My book says you can remove the oil pan w/o pulling the motor, but with the engine jacked, and the tranny hitting the body, the pan will not clear the front diff. I put the pan back on with two bolts and plan to pull the engine soon.
Old 10-10-2004, 01:27 PM
Ok, i haven't been back for a bit, i was getting a good way to check the fuel pressure while driving and have determined that that the fuel pressure acts the same wether it is "acting up" or not. It seems to do just what it is supposed to.
Old 10-11-2004, 10:01 AM
marcwert marcwert is offline
marcwert is starting off with a positive reputation.
14 is from the pickup in the distributor. at one time there was aproblem with that. they are a hall effect sensor and the magnet can crack. if after changing the TFI the 14 went away it is possible that the pip was bad and by tapping it by working on the distributor it wont give the code but is still bad. you have to pull the dist to replace it.
put and inductive tach on and if the rpm flutters driving at higher speed you are dropping spark could be low side or high side. put a coil tach on or dwell meter and in the same drop or flutter happens it is your low voltage side. wires could do this but usually it is more prevelant an low speed takeoff load.
Old 11-13-2004, 09:36 PM
TRIT0N TRIT0N is offline
TRIT0N is starting off with a positive reputation.
my 88 ranger 2.9 is behaving exactly like yours
after 10-15 mins city driving it bogs right out and can't get it to pull over 3000 rpm's
i have changed the tps sensor, ignition module, o2 sensor and all have provided no results
its been doin this over a year now but i have only had the truck 3 months and with a very limited budget i can't do much
so any help would be greatly appreciated
Old 02-13-2013, 08:58 PM
jolinberg jolinberg is offline
jolinberg is starting off with a positive reputation.
change te ECU.. same thing happened to mine cold runs fine and then warmed up it bucks an jerks and idles bad
Intermittent Power Loss truknoob 1994.5 - 1997 7.3L Power Stroke Diesel 73 Today 03:35 PM
Knocking from bellhousing area Slogeris30 Connecticut Chapter 3 11-22-2015 08:04 PM
1993 E350 Cutaway Motorhome - Dredded "loss of power" Chris Blackburn 1968-2013 Full Size Vans 11 09-09-2013 10:17 AM
Expedition rough idle Fujis123 1997-2006 Expedition & Navigator 15 01-03-2012 09:52 AM
Severe misfires on warm start? iamoz Ranger & B-Series 1 07-13-2011 09:39 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
29, 86, 88, bad, bronco, ect, ford, ii, load, loses, loss, marks, power, sensor, symptoms, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
