Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
  #1 (permalink)
Old 04-22-2000, 04:01 PM
Ranetti Ranetti is offline
Garage is empty, add now
Ranetti is starting off with a positive reputation.
1988 Aerostar Purchase
I have just purchased a 1988 Aerostar XLT with 35,500 original miles on it. It is very clean and runs excellent, except it has a slight valve tap. Is this common in this engine and application? I've owned an "87 Taurus and a '92 as well and have never heard either 3.0 make sounds like that. It seems to go away and come back, but under acceleration froma stop, it is noticeable. Other than the cheap original radio, it's a great little machine.
  #2 (permalink)
Old 04-22-2000, 07:33 PM
MarkP MarkP is offline
MarkP is starting off with a positive reputation.
That is low miles for an 88. I've got slightly less the 60K on my 88 a Aerostar and the engine makes no such noise. Perhaps yours sat around unused enough and missed some oil changes and a valve lifter has become sticky. You might try an oil change including a can of upper cyclinder head lube like Marvel Mystery Oil for a few miles to free up the lifters and then do another oil/filter change back to freash oil if it frees up. I've had very good luck with this process on a couple of engines with stuck lifters in past.
  #3 (permalink)
Old 04-23-2000, 08:45 AM
I thought something like that might be called for, but hearing it from someone else reinforces that opinon. Thanks for your input.
  #4 (permalink)
Old 04-25-2000, 05:42 AM
TallPaul's Avatar
TallPaul TallPaul is offline
2001 Ford Ranger
TallPaul is gaining momentum as a positive member of FTE.
__________________
'01 Ranger, 2.3L, 5 speed, 83,000 miles. Redline MTL, Amsoil Signature 5w20, Wix Oil Filter, Dynomax Super Turbo muffler.
Tags
1988, aerostar, change, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
