5.0L Explorer/Mountaineer dyno numbers
Old 09-18-2004, 09:10 AM
NitrousAl's Avatar
NitrousAl
NitrousAl is offline
Question 5.0L Explorer/Mountaineer dyno numbers
Does anyone know what kind of chassis dyno numbers a stock 5.0L Explorer or Mountaineer makes? Is 170-180 rwhp accurate?
Old 09-18-2004, 10:19 PM
Blly177's Avatar
Blly177
Blly177 is offline
210 at the crank
Old 09-18-2004, 10:58 PM
NitrousAl's Avatar
NitrousAl
Question
I thought the Mustang Cobra motor was rated at 240 hp. All the pieces are the same except the camshaft, right?
Old 09-19-2004, 04:32 PM
D-Rock's Avatar
D-Rock
D-Rock is offline
Actually, it should be 215 at the crank with 288lb/ft tq (not splitting hairs, Blly ).
As far as at the wheels, it depends on the drivetrain setup too. AWD, 2WD, or 4x4 will all have an impact on hp loss, so your estimates may not be too far off,
Which year Cobra are you referring too (early 90s?). There are differences in air intake and exhaust on that car vs. the EXP/MNT setup.
Old 09-19-2004, 07:54 PM
NitrousAl's Avatar
NitrousAl
Ford gave the 5.0L Explorers and Mountaineers the GT40/Cobra/Explorer intake, a 65mm TB, GT40P heads and it only made 215 hp at the crank?
Old 09-19-2004, 08:10 PM
D-Rock's Avatar
D-Rock
D-Rock is offline
Crazy, isn't it? It is capable of more, but there's work to be done.
Stock exhaust manifolds suck (example: 1st and 3rd cylinders share an exhaust tube, as do the 2nd and 4th), due to the limited space caused by AWD or 4WD parts. Then they funnel a nice dual exhaust setup through 4 cats (2 on each bank) into a single out muffler, followed by secondary muffler/resonator. Lastly, the intake has one of those silly air silencers that is about 60% of the size of the TB.
I have an '01 Mounty w/ AWD and am in the process of changing all this crap. Already have put on a MAC intake (small improvement) and will address the exhaust soon. FMS used to make headers for this setup, but discontinued them. I did see a post here not too long ago from a custom guy, but he wanted about $800 for a set (too much )
I'm not certain about the cam, but there may be those that can speak up to it.
Old 09-19-2004, 08:46 PM
NitrousAl's Avatar
NitrousAl
Question
Do you still have your stock Mountaineer intake manifold? Is it for sale?
Hendrik
Electrical Systems/Wiring
01-19-2023 02:30 PM
Hendrik
03-11-2017 02:50 AM
Mikeman
09-18-2013 02:45 PM
640 CI Aluminum FORD
2009 - 2014 F150
46
04-14-2011 09:44 AM
robo-randy
02-16-2005 02:24 PM
Quick Reply: 5.0L Explorer/Mountaineer dyno numbers
