Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 09-17-2004, 06:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
The rain, just the rain man.
How is everyone fairing with the rain?
We have had 1.5 inches in Nutter Fort since it started last night as of 7 PM.
Still raining now.
Our creeks and streams are getting muddy and coming up slowly. They are all still in their banks as of now.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #2 (permalink)
Old 09-18-2004, 07:44 AM
fitter565's Avatar
fitter565 fitter565 is offline
Garage is empty, add now
fitter565 is starting off with a positive reputation.
Not good, For the first time since I've owned my house the basement walls decided to turn into a sprinkler head! So I've got alot of cleaning and trashing alot of stuff. Then I have to figure out how to fix this problem. Any idea's???
Mike
__________________
2005 Explorer Sport Trac XLT Premium
2002 Escape XLT 4x4 3.0 v6 (Wifes ride)
Support FTE
  #3 (permalink)
Old 09-18-2004, 08:12 AM
Crazz's Avatar
Crazz Crazz is offline
Crazz is starting off with a positive reputation.
Unhappy ouch!!
sorry to hear that fitter, i was lucky no rain damages here. feel sorry for anyone who suffered water damages to a home or vechile
__________________
Richard
1978 E250
dual tanks
2wd
351W
  #4 (permalink)
Old 09-18-2004, 09:07 AM
fitter565's Avatar
Thanks Crazz, we'll get through it and get things fixed.
Mike
__________________
Support FTE
  #5 (permalink)
Old 09-18-2004, 07:26 PM
1997 Ford F-350
My Garage
Sorry for your misfortune. From what I saw on the Weather Channel I was kinda worried about you, Rod and wvbeer.
Yes, I do know how to fix it. I am good at that kinda stuff. Wanna have the meet and greet in your basement......wait, in your garage....do not want to wade water over to the coffee pot. Then I can look at your problem and offer a solution. I kinda need to see the house and lay of the land to know what is needed.
Was this from a stream flooding, surface run off or bad footer drains?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 09-18-2004, 07:37 PM
fitter565's Avatar
Thanks Dave, it was from surface run off and no footer drains. I had the yard leveled when I built the garage. Looks like they didn't get the slope just right. I'll look into gettng some more dirt brought in and slope it away from the house. It looks pretty level now. Then I'll figure out what to do.
Mike
__________________
Support FTE
  #7 (permalink)
Old 09-18-2004, 08:38 PM
1997 Ford F-350
My Garage
Dig around the house down to the footer.
Then go three inches below the top of the footer.
Put 2" of clean 57 stone in the bottom.
Schedule 35 preforated pipe goes in next.
If you are on a hill and can do it a natural drain out of this pipe is desireable.
Fill the rest of the hole with clean 57 stone to ground level.
Also the ground should slope away from the house at least 1" per foot for at least 10 feet.
If you do all of these things your basement will never be wet again.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #8 (permalink)
Old 09-20-2004, 08:17 AM
wvabeer's Avatar
wvabeer wvabeer is offline
wvabeer is new and has a neutral reputation at this point.
I just got a little in my crawl space under my house my yard is pretty dam level it's hard to get the water to go around my house but no damage otherwise
__________________
Kenny
04 F350 reg cab, 4X4 ,V10 ,6sp ,430 gear, 315/75/16
94 Ranger, reg. cab, Shortbed, 4.0, auto
  #9 (permalink)
Old 09-21-2004, 05:56 AM
fitter565's Avatar
Thanks for the info Dave, I'm going to put a inside french drain in also. That should help out some to.
Mike
__________________
Support FTE
  #10 (permalink)
Old 09-21-2004, 09:34 PM
1997 Ford F-350
My Garage
If your yard is real flat and you have no natural drainage you may have to install a well and a sump pump.
I do not like to use a pump unless I have no other way to drain the french drain.
Some of these rains we have been having would take a huge pump to keep up with the water running in.
Try to stop the water outside the house. Water does damage to the blocks when it comes through them.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #11 (permalink)
Old 09-23-2004, 06:52 AM
wvabeer's Avatar
thanks for the info dave
__________________
Kenny
  #12 (permalink)
Old 09-24-2004, 04:26 AM
fitter565's Avatar
Thanks Dave, Alot of great info and thanks for the pic's. Still trying to get things cleand up. What a job that is...lol. I have a couple of contractors coming in today, so we will see what they have to say. I'll let you know when I find out.
Mike
__________________
Support FTE
  #13 (permalink)
Old 09-24-2004, 07:02 PM
1997 Ford F-350
My Garage
I can answer that question. Give us lots of dollars, we can fix your problem.
I just hope they know what they are doing. Ask for references from past similar jobs.
A lot of BS'ers out there. I get to fix lots of others attempts to dry up basements.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #14 (permalink)
Old 09-24-2004, 07:29 PM
fitter565's Avatar
Wanna bid on mine? If you do let me know.
Mike
__________________
Support FTE
  #15 (permalink)
Old 09-25-2004, 09:41 AM
1997 Ford F-350
My Garage
It would not be any time real soon, we are sooooo busy. Other than that, love to. How far from me are you? 669-1253
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
