Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-17-2004, 03:39 PM
EconoDan EconoDan is offline
Garage is empty, add now
EconoDan is starting off with a positive reputation.
What the largest engine I can get into a 61 Econoline pickup?
easy question - easy answer?
Looks like perhaps a 300 I6?
(or at least a 223?)
Seems like I saw someone put in a 302 once.....can't remember.
Would be great if I could get a 390 in there. I don't mind changin' a few things around to make it work. (already have a 390 + C6 sittin around...)
Dan
  #2 (permalink)
Old 09-17-2004, 05:36 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
royal pain to put anything bigger in a 61 than a 200. i sent you an email, reply and i can get you some more info, and a few econo owners in arkansas to get together with.
__________________
jim
underated and overworked.
  #3 (permalink)
Old 09-17-2004, 09:04 PM
How about a 66?
Thanks for the email - reply sent.
  #4 (permalink)
Old 09-17-2004, 10:17 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
In the day they put 289's in them. A 302 will go also. I had a book that showed the whole swap...lost it to an Econoline owner in 1977.
For the bigger stuff, you are looking at cutting the floor out and makeing a custom dog house and and and....
Anyway, since you can stroke & poke a 302 out to 347, I'd say if you want the biggest thing that will fit, go stroker small block.
  #5 (permalink)
Old 09-20-2004, 03:55 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Are the dog houses larger on the 65-67's with the 240 six? I have a 63 with the 144 and wouldn't mind a 300.
  #6 (permalink)
Old 09-20-2004, 04:43 PM
exactly what I was thinking.....
I saw one on ebay with a 302 in it....got me thinking. since it's got a 6 in it already, wouldn't a bigger 6 make sense?
thanks for the email, Jim!
  #7 (permalink)
Old 09-20-2004, 08:07 PM
Jimbare's Avatar
it is as much work to put a big six in a 61-64 as it is a v8. and yes the big six dog house is bigger, and there is a hump in the floor at the rear of the dog house for the bellhousing to clear.
__________________
jim
  #8 (permalink)
Old 10-06-2004, 11:16 AM
My experience with the 300 I6 is what makes me really want to put one in there. I'll look for a 65-66 body if you think I could do it. I don't mind taking my time with this one - gone start from the ground up anyway....
Dan
  #9 (permalink)
Old 10-06-2004, 12:27 PM
I've got a 300, and I used to have a 289. My advice: Got get some time behind a 289 or 302......
  #10 (permalink)
Old 10-06-2004, 12:41 PM
you've got a 300 in an Econo-truck?
Pics?
  #11 (permalink)
Old 10-06-2004, 01:56 PM
No, My 300 is in an '85 E150, not the early model. My 289 was in a Mustang.
What I'm saying is the 289 or 302 with the right cam and carb will run real nice at low rpm. It won't have the off idle torque of the 300, but it will come to life at 2200 rpm or so.
In a vehicle the weight of the early Econoline, I would think you'd be very happy with a 289 or 302.
And you won't have to do some unsightly sheet metal mods to wedge it in there.
  #12 (permalink)
Old 10-06-2004, 03:14 PM
Couldn't one get a dog house from a 65-67 with big six and the cross members. Cut the floor to size and replace the crossmembers and drop the big six in?
You have to change crossmembers to put in a v8 and mod the dog house for width too.
Seems it should be a horse a piece if you have a Van. Does the dog house go to the rear of the cab in the PU?
I vote for the 300 or a Turbo 2.3 four from a TBird
Dan
  #13 (permalink)
Old 10-06-2004, 06:31 PM
Jimbare's Avatar
65 ,66,and 67 can have a 300 put in with all stock parts. you have to do a lot of changeing to get it there, but it can be done.
if a 300 is what you want, then that is what you should puy in it.
__________________
jim
  #14 (permalink)
Old 10-06-2004, 07:13 PM
pendentive pendentive is offline
pendentive is starting off with a positive reputation.
Jim - you're dangerous.....
"Sure...go ahead and pull the trigger if you really want to..."
I guess I am kinda bent on putting in a 300....my father-in-law loves 'em and has me convinced they're the best thing since buttered toast.....I figure if I give in and put one in.....then he should be available to help out when I need him......right?
  #15 (permalink)
Old 10-06-2004, 08:19 PM
Jimbare's Avatar
he has no idea what he is getting both of you into! as i said, it can be done with all factory parts, it just aint easy!
__________________
jim
Tags
1961, 23, 6164, 67, biggest, burton, diesel, econoline, econolinepickup, engine, ford, johnny, metal, pickup, sheet, swaps, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
