Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #61 (permalink)
Old 10-11-2004, 11:26 PM
OSBUCKEY is starting off with a positive reputation.
Just made a trip from southeastern,Oh to Richmond,VA . Stoped by the state fair and to see family. Tried to keep it around 70 but hard to do sometimes. Run out about one and a half tank of fuel. Got 19.3 mpg for all fuel and miles. 03 X 6.0 27,000 miles on it. lie-o-meter reads 16.7 and never changes city or highway.
  #62 (permalink)
Old 10-12-2004, 10:11 AM
jdadamsjr is starting off with a positive reputation.
OS...
you need to reset the overhead periodically unless you WANT to know the average of the fuelage from the day you bought the truck....
hold in both buttons at once until it resets....
__________________
05 Ex 4x4 6L -Walker BTM, 9005's fogs, GOSRACING headlight wiring harness, Silverstar 9008's, SCT is all - 8.9 @ 75 1/8th!
Gone but not forgotten -2003 Ebony Ex, 4x4 6L Westin Bull Bar, PIAA 520's, PIAA Headlamp UpgradeTurbo-back Exhaust...
even goner-2002 4x2 7.3L Ex Limited-buy back
  #63 (permalink)
Old 10-12-2004, 12:57 PM
Fords4Me's Avatar
Fords4Me is starting off with a positive reputation.
2001 X 7.3 w/3.73's get an average of 15.0 highway at best. Do I need to start looking for a problem?
  #64 (permalink)
Old 10-12-2004, 01:09 PM
jimmyboy is starting off with a positive reputation.
fuel economy on 05 excursion diesels
Anyone out there take delivery of an 05 diesel excursion yet? Just wanted to know how fuel economy compared to previous years. Thanks, Jim
  #65 (permalink)
Old 10-13-2004, 12:10 AM
Thumbs up
Hay JD thanks for the reset info. Reset it today, should it be reset on every tankful and will that give you the mpg for that tank.
  #66 (permalink)
Old 10-13-2004, 12:48 AM
Toreador_Diesel's Avatar
Toreador_Diesel is gaining momentum as a positive member of FTE.
Post
Quote:
Only 15?!?
How fast are you driving?
Check my sig, I get 17 almost 18 mpg by doing 65, and on occasion 70 on the freeway. (I always try to maintain either 45 or 50 in town) The only reason you get an average like 15 is if you do about 80-85 mph on the freeway. If you do around 65-70 mph, you'll see about 17-19 mpg (20 if you're lucky) as opposed to 15.
You could also have a dirty air filter, fuel filter or both.
BTW, is this according to the overhead computer or did you do this by hand?
__________________
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
Sonnax/Tricumulator kit
V10 Trans Cooler
Power, Heat, Lighted, Signal TT Mirrors
6 inch PROcomp lift
315/75/16 BFG AT K/Os
9007 Bosch HIDs
4.10 Gears
WW
  #67 (permalink)
Old 10-13-2004, 05:57 AM
Fords4Me's Avatar
Using the overhead. I reset it each tankful. I have gotten over 700 miles out of a tank 1 time. The air filter is in good shape, the X has 38k on it now. I have never replaced the fuel filter, and there are no driveability issues. She just seems to like her fuel. Alot. As far as speed there should be no issue, where I live you don't want to be more than 9 MPH over the posted 55, or they make you pay a special tax with a piece of yellow paper. I thought it should do better. The wife uses the cruse control set at 60 most of the time, the area is a little hilly, and she gets around 14.8. HELP!
  #68 (permalink)
Old 10-13-2004, 05:59 AM
Fords4Me's Avatar
BTW, purchased the vehicle about 8k ago.
  #69 (permalink)
Old 10-13-2004, 06:13 AM
Quote:
How often you reset depends on what you want to measure..
or a better word would be what you want to "guesstimate"
since the overhead shows trends only and has not been proven to be accurate by most....
Curious though that the ones I have heard are inaccurate are ALWAYS higher than the actually mpg you get !!!
Is it a conspiracy
but I usually DO reset each tank.... since I'm not overlly concerned about mpg, I just like to see the trends on different tanks, not the averages of many...
__________________
  #70 (permalink)
Old 10-19-2004, 09:36 AM
damone is starting off with a positive reputation.
Just got a 2001 4x4 7.3L. I got 7.5 towing 8K lbs. Hopefully that's not right.
  #71 (permalink)
Old 10-19-2004, 09:48 AM
Fords4Me's Avatar
I know I'm not impressed with the fuel efficiency. I guess the next thing is to take it to the dealer to see what they say, I'm just very reluctant since they warped my rotors when they did the tire recall.
  #72 (permalink)
Old 10-19-2004, 11:21 AM
Thecomputer was dead on as far as the mileage said compared to hand calc. It said it was getting 19 mpg when we drove it home from the dealer with a/c maxed in OD on flat freeway.
  #73 (permalink)
Old 10-19-2004, 01:46 PM
bluerage is starting off with a positive reputation.
I just swictched to an afe stage 2 proguard filter, added some diesel kleen additive, and properly inflated all tires, picked up a couple of mpg's....VERY happy with the results...although the filter was a bit pricey...
  #74 (permalink)
Old 10-19-2004, 03:24 PM
redwingsfan is starting off with a positive reputation.
What kind of tire pressures are the best for fuel mileage/tire wear? I know what the recommendation is at Gross Weight, but what about normal everyday type driving where you are not loaded down?
  #75 (permalink)
Old 10-19-2004, 11:26 PM
Quote:
Originally Posted by bluerage
I just swictched to an afe stage 2 proguard filter.......picked up a couple of mpg's....VERY happy with the results...although the filter was a bit pricey...
I've read about the stage 2 kit and the 50 hp and 112 ft/lbs. it gives you at 1900 rpm. Now that you have one, I'm really curious. How much of a difference did you notice with the stage 2 kit? and How many mpg did you pick up?
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
