Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #31 (permalink)
Old 09-22-2004, 10:14 AM
jdadamsjr is starting off with a positive reputation.
Curious too what the differences could be....
ti is the same engine, is it not ?
I know when my egr wire was blown off and has been disconnected for a WHILE...
it still runs fine....
actually better than fine since I don't have to worry about the EBP sensor going out
__________________
05 Ex 4x4 6L -Walker BTM, 9005's fogs, GOSRACING headlight wiring harness, Silverstar 9008's, SCT is all - 8.9 @ 75 1/8th!
Gone but not forgotten -2003 Ebony Ex, 4x4 6L Westin Bull Bar, PIAA 520's, PIAA Headlamp UpgradeTurbo-back Exhaust...
even goner-2002 4x2 7.3L Ex Limited-buy back
  #32 (permalink)
Old 09-22-2004, 11:07 AM
RoyC is starting off with a positive reputation.
I really do not know what would be different, however, reading the MPG post on this site and others since the 6.0L came out it appears the Excursions get better milage than similiar F-250's. This, if ture, could be the software programing. Ever since my engine started acting like it was broke in the milage has been 19.98 MPG for the last 23,000 miles. A lot of 250 guys would fight for that number.
RoyC
__________________
2005 Limited Excursion with 2005 MY 6.0L engine, 4X2.
  #33 (permalink)
Old 09-22-2004, 11:14 AM
ZBeeble's Avatar
ZBeeble is starting off with a positive reputation.
Well... the milage thing could be many factors. The stock 'X is lower down ... so there may be some ground effects. The 'X also has one back plane ... so maybe it compares with a truck that has a cap ... but the aerodynamics of a pickup are different.
That all said, if the "tune" of the X is different and people with a "chip" see some milage benifit, then 'X owners should see less benifit? You'd expect that the mpg benifit would have to be in the pedal range for running down the highway... since the 'X is heavier ... there shouldn't be an potential for winning there.
__________________
04 EB PSD X, no mods (yet)
  #34 (permalink)
Old 09-22-2004, 01:17 PM
Toreador_Diesel's Avatar
Toreador_Diesel is gaining momentum as a positive member of FTE.
Frustrating isn't it?
I've been reading this thread for quite some time now, and now that yourself and the rest have mention this, I'm confused.
The X weighs more than the F-250, yet somehow it does better on mileage. I think it's the whole therory that the X is an F-250 with a built on cap. Cut the "cap" off an Excursion, and just watch the mileage drop. Aerodynamics probably plays a role in this too. But then again, who really knows for sure?
__________________
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
Sonnax/Tricumulator kit
V10 Trans Cooler
Power, Heat, Lighted, Signal TT Mirrors
6 inch PROcomp lift
315/75/16 BFG AT K/Os
9007 Bosch HIDs
4.10 Gears
WW
  #35 (permalink)
Old 09-22-2004, 01:19 PM
The X weighs more than the F-250, yet somehow it does better on mileage. I think it's the whole therory that the X is an F-250 with a built on cap. Cut the "cap" off an Excursion, and just watch the mileage drop. Aerodynamics probably plays a role in this too. But then again, who really knows for sure? I sure don't.
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
  #36 (permalink)
Old 09-22-2004, 01:27 PM
ZBeeble's Avatar
Well Aerodyamics play a role in the highway fuel efficiency. Weight plays in the "city" efficiency ... since weight, once rolling, isn't really a factor.
So I'd expect the same city performance in a 250 ... maybe slightly better and I can explain (in my mind) why an 'X might get better highway milage.
I expect that a tune could aid in the highway milage since the engine is only running at a few percent of it's capacity ... there's probably a number of tweeks that could help. Something I was reading somewhere was that higher boost could provide more complete burn ... so efficiency would be higher. I don't see the program helping in city driving much as a certain amount of work is required to get the vehicle up to speed ... and that work is higher for the 'X.
__________________
  #37 (permalink)
Old 09-22-2004, 01:28 PM
ZBeeble's Avatar
BTW... does the "junior user" tag change at 100?
__________________
  #38 (permalink)
Old 09-22-2004, 01:53 PM
Keep trying, you'll get there ---
I fin that if your break each thought into 4 or 5 posts, you get there quicker
__________________
  #39 (permalink)
Old 09-22-2004, 03:37 PM
psdwanabe's Avatar
psdwanabe is starting off with a positive reputation.
HMMMMM.....Ill
__________________
No longer a wanabe, now a have!
2004 X Limited, 4X4 6.0 PSD Pueblo Gold
10/23/03 X Build
10/20/03 Engine Build
Pilot Injection?
  #40 (permalink)
Old 09-22-2004, 03:38 PM
psdwanabe's Avatar
have to give
__________________
10/23/03 X Build
Pilot Injection?
  #41 (permalink)
Old 09-22-2004, 03:39 PM
psdwanabe's Avatar
that a try sometime.
__________________
10/23/03 X Build
Pilot Injection?
  #42 (permalink)
Old 09-22-2004, 06:11 PM
PowerStroke King's Avatar
PowerStroke King is starting off with a positive reputation.
The difference in mileage is due to the aerodynamics of the F-250 body compared to the Excursion body. The drag coefficient on the Excursion body is lower.
If F-250 owners put a net up in place of the tail gate, it will help the mileage.
__________________
1965 Mustang
1967 Galaxy
1968 F100
1968 Galaxy
1969 Galaxy 500
1970 Maverick
1973 Gran Torino
1979 Crown Victoria
2001 Windstar Ltd
2004 Freestar Ltd
2004 PSD/6.0L X
  #43 (permalink)
Old 09-22-2004, 07:00 PM
Quote:
Nice! lol
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
  #44 (permalink)
Old 09-25-2004, 11:51 PM
dddenio is starting off with a positive reputation.
01 f250 CC PSD 4x4 & 02 Excursion PSD 4x4
I must need to disconnect the EGR because my X ALWAYS gets 1-2 mpg less than F250. F250 has a high cap. With cap removed the truck will get the same milage or 1 mpg better. Our X NEVER gets better milage than truck, EVER!
Best trip mileage on F250 going to SC is 21mpg @75mph, regularly MPG 17.5
Best trip mileage on X going to Fl is 19mpg @75mph, regularly MPG 16
Neither will go below 15, no matter how fast or how hard I drive em. until I'm towing, then will run 10.5 to 12 mpg. I'm told towing milage would increase if I'd slow down to 65, someday I'll check.
Dennis
__________________
02 7.3L Excursion 4x4 FTVB, MBRP 4" SS, Ranchos, "V" & "B" Codes, AirBags, Rear Hellwig, Coolant Filter Kit & 203 stat, Tank Mods 01 7.3L F350 CC LB 4x4 5" Exh guages BTS trans US Gear DP 6 pos chip V10 Trans Cooler Coolant Filter Kit Evans 203 stat DI reg Fuel GT38R BB Turbo AFE 2 Banks IC Air Bags
  #45 (permalink)
Old 09-25-2004, 11:53 PM
ddd...
If I cared about mileage on my 8k lb vehicle...
I'd LOVE to get that mileage on my X....
Guess I drive too fast...
are you manually calculating that or using the overhead ?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
