clink?
Not sure if your rear shaft is a one piece or 2 peice but either way, it could be u-joints. On mine, there is a boot near the end of the shaft. You can cut the strap on it, pull it and it will seperate from the other part of the shaft. Clean it real good and then grease the joint. It is called a slip joint and it WILL make a clinking noise on most models. Put the rubber boot back on and secure it with plastic wire ties. Oh yea, you may want to drop the entire shaft so that you can check your joints but for the slip joint, you only have to drop the rear section.
Good luck,
Good luck,
mudrat025
35
09-24-2013 01:35 AM
chrismartinez0
05-27-2010 08:12 PM
