Engine knock? - Ford Truck Enthusiasts Forums
Engine knock?
Old 09-16-2004, 10:29 AM
ChuckRock ChuckRock is offline
ChuckRock is starting off with a positive reputation.
Engine knock?
I have an 83 Ranger 2.3L 4. It had been setting for a few years. It was/is going to be a V8 swap project. Iíll get headed that way again soon. But for now I am using it to get to work and back.
I am having a knock/rattle that is coming from the engine at higher rpm under a load (like going up a hill or take off). It does not matter what gear I am in. But when crusing it does not make a noise. I have change the oil and use some of that engine rebuild stuff (thick oil) to see if that would take care of it for now, but it still makes the noise. I have not checked the valve clearance yet, but I would think if that was the problem I would hear it at idle. It could be a rod may be, but I am not sure.
Can anyone get me some suggestions (cheap!)?
Oh, I canít do the engine swap for a couple of months. (Have to get all the parts and have the time to do it.) So that would not be a good fix for now. Hehe
Thanks
Old 09-16-2004, 08:44 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
So, this noise isn't "ping" ? Try some premium gas just to be sure.
AL.
Old 09-16-2004, 10:49 PM
No it's not ping. It does it even with 92 gas.
Old 09-17-2004, 08:25 AM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Rod bearings usually make their noise on decceleration or if you snap the throttle.
Mains on a heavy pull, deep heavy knock.
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
