What is crossover steering?
OK guys,
Forgive my ignorance. . .but what is cross-over steering? I understand it has something to do with a lifted truck, but what is involved?
How high can I lift my truck ('78.5 F150 SC 4x4, stock suspension, 31x10.50's)before I have to be concerned with steering?
cross over steering has a big tie rod conecting the steering knuckels but its on the back side and then the drag link is connected on the left steering knuckel or at lest thats what i think it is. you will have to put a drop pitman arm if you put a suspention lift on.
hope this helps
matt
hope this helps
matt
My 78 F250 4x4 is lifted with a 4" Rancho suspension and 3" body lift. I dont need it with the 4" lift but I plan on going higher and bigger.
I plan on doing mine once I decide how high a lift I want and Atlas Spring will be making my leafs.
Heres a couple sites to learn more.
http://www.pirate4x4.com/tech/billav...ngresearch.htm
http://4wheeldrive.about.com/gi/dyna...et%2Fxover.htm
Crossover steering uses a link that runs from your pitman arm to an arm attached to the top of the passenger's side steering knuckle. This gives you better leverage for steering vs. a drop pitman arm and works well for 6" or bigger lifts.
The following users liked this post:
My bad. He was just over here and we got a little tipsy so I'm still not thinking straight. Here, this is looking from the driver's side toward the passenger's side:
Check out his crossover gallery here for more pics and details: https://www.ford-trucks.com/user_gal...hp?userid=5979
william16339
08-27-2019 10:35 AM
78fordguy
21
02-21-2017 11:44 PM
Phildo
04-15-2016 11:54 PM
sfeverall
08-24-2012 11:56 AM
countryshiz87
12-09-2011 11:07 AM
