Ford F150 Starter Replacement - Ford Truck Enthusiasts Forums
Old 09-15-2004, 06:57 PM
SIR LAWRENCE SIR LAWRENCE is offline
SIR LAWRENCE is starting off with a positive reputation.
I have a Ford F150 1997 4.6 (I think) engine. I bought a starter to replace the one that is failing. In 4 hours I have been able to remove only two of the three bolts holding it on. The top one is the problem, it simply cannot be reached. I even removed the right front tire hoping that would help the access but even with socket extensions combined, there is no room to ratchet even when i do get the socket over the head. It does appear I might get more room if I remove the manifold from the block but is all that necessary to get at it, or is there something else to be removed?
I can be reached at hhprmotn@comcast.net
Ticked off and tired
Larry
Old 09-15-2004, 10:42 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi Larry and welcome to FTE
The engineers did a good job of designing the starter mounting eh?
I've replaced quite a few of these starters and I just use a few different extensions and deep and shallow sockets until I find what reaches. You have to go in from just in front of the starter. I usually put the socket and extension on the bolt and then put the ratchet into the extension.
It's not a fun job but it can be done without removing anything else.
Old 09-16-2004, 12:30 AM
Smile Hey, thanks!
I appreciate the tip. I have tried various extensions but to no avail. Since I cannot even get an socket over the bolt, I am not certain if it is a 11mm, 12mm or 13mm. I even went to our local library this evening hoping that somewhere in the volume of truck repair manuals it might at least give me what socket to use but ran into a dead end there as well. I have big hands and cannot get my hand far enough in to the opening to make the connection so will most likely try removing the manifold to give me some space. Thanks again.
Larry
Old 09-16-2004, 01:24 AM
Racerguy's Avatar
It's a 13mm.
Taking the manifold off a 4.6 isn't real easy either so I'd just fight with it without removing the manifold.
If you do decide to remove the manifold though the easiest way by far is to remove the inner fender liner and go in from there.
Old 09-16-2004, 09:02 AM
Prompt response was appreciated
Again, thanks. You were most helpful.
Larry
Old 09-17-2004, 08:29 AM
brownie65 brownie65 is offline
brownie65 is starting off with a positive reputation.
I just took one off yesterday. As was said I grabbed a handfull of extensions & a deep & shallow 13 mm socket. I got the right combo & actually had plenty of room to work the ratchet to get the bolt out. I had to have the ratchet on the bottom side of the frame,wouldn't work on the topside.
Old 09-17-2004, 10:05 AM
Thanks for the help. I finally got it out by taking the passenger front wheel off and used a combination of extensions and surprise (a 10mm) socket, angle connection attachment and brace handle to do the job. Apparently at one time or another someone substituted a 10mm for the 13mm soOnce the top one was gone, everything went smooth. You and all those who responded was most appreciated.
Thanks again
Larry Harris
AUTO ENGINUTY FOR SALE sleepyhead416 All Other Items for Sale 4 09-18-2015 02:41 PM
Progress being made (pic heavy) Indybeer 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 08-13-2013 10:37 PM
2009-2011 f150 xl front crossmember collaborative f150 2009 - 2014 F150 0 03-29-2011 05:34 PM
How do I remove my yoke off the pinion of my rear pumpkin? Please advise ASAP mikelee 1997 - 2003 F150 3 07-13-2010 04:49 PM
352 up for grabs EricJ New England Region 0 04-24-2010 05:12 PM
Tags
08, 1978, 1997, 2006, 97, f150, ford, forum, location, remove, removing, repair, replacement, replacment, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
