Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-12-2000, 11:40 PM
nitro94's Avatar
nitro94 is starting off with a positive reputation.
Aerostar wheels
__________________
Lynn
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-23-2001, 07:29 PM
87f2504x4 is starting off with a positive reputation.
Aerostar wheels
Anyone have any luck fitting 15 inch tires/wheels under their Aerostar? I am thinking of putting a set of Ranger/Explorer aluminum rims on mine with 235/75 tires. Anyone try this? I know the bolt pattern is the same, but will I have clearance issues with the larger tires?
The harder you work, the harder it is to surrender...
  #3 (permalink)
Old 01-23-2001, 10:23 PM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
Aerostar wheels
The P235 75R15 tires will work on the rear, no problem. However, they are too tall for the front, when turning full chock, left or right. I have a friend who has stock 15" Explorer alloy wheels off of a '95 Explorer on his '96 burgandy Aerostar cargo van. Suggestion: Replace the P235 75R15 tires with a set of P225 70R15's The 225's are about the same height as a P215 75R15 tire, easily mount on the stock Explorer rims, and look great on an Aerostar, especially with RWL such as Dunlop's GT Qualifiers, Goodyear's Wingfoot radials (Note, avoid the Goodyears. Affordable price, stunning looks, but they are made with a soft rubber compound that wears quickly, even with a vehicle that is properly aligned and correct air pressure) BF Goodrich Radial TA's RWL, will wear much better. Anyway, hope this helps. The 225 70's fill out the Aerostar's wheelwells nicely, and still give the van a comfortable ride. The key is using a stock 15" wheel with little or no offset.
  #4 (permalink)
Old 04-06-2001, 03:08 PM
aerocolorado is gaining momentum as a positive member of FTE.
Aerostar wheels
Tire Rack (tirerack.com) has a nifty site where you can view different tire/wheel combinations on your specfic vehicle. Shows you how even a 16 or 17 inch wheel could work.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
