What is draining my battery?
battery drain
Hi ,Im new here but I had an areostar once and know alot about them. I would first run a test light or meter between the pos side of the battery and the main connector. The light on shows a draw. Then remove one fuse at a time till it goes OFF and you will see where the draw is. Hope this helps. great Forum
Mine lets me key out in any position too. And Taurus ign. swithc now lets me pull out key in any position.
I remember Gaselle van that was in our company. Ign switch was broken and they installed switches and start button like in plane. was sold last year.... boost controll valve and boost pressure sensor were bad and she ran in clouds of black smoke (engine - Iveco Marine 2.9TDI)......
