1986 F150 Fuel Pump Relay Location
Old 09-15-2004, 09:07 AM
1970moose's Avatar
1970moose
1970moose is offline
Dang, I had an '86 bronco and the fuel pump relay was on the driver side fender. However, I can't find the one for my '86 F150. Anyone know where ford stuck this thing? Thanks.
Old 09-15-2004, 09:18 AM
MRStace84's Avatar
MRStace84
MRStace84 is offline
Are you sure it doesn't have a mechanical fuel pump? My 84 I-6, does.
Old 09-15-2004, 09:45 AM
1970moose's Avatar
1970moose
100% sure. I have EFI. My fuel pump won't shut off. I believe the relay is either stuck or has grounded out somewhere along the way.
Old 09-15-2004, 05:52 PM
Neospawn's Avatar
Neospawn
Neospawn is offline
According to hayes manual the relay box is mounted in the engine compartment against the left side fender apron. On lid it should tell you which relay you need.
Old 09-15-2004, 07:24 PM
Beast12's Avatar
Beast12
Beast12 is offline
For my 85 it is between my brake fluid reservoir and the driver's fender on the firewall. You have to pull it out of it's "holder"
-Matt
Old 03-26-2017, 10:39 AM
John Holloway's Avatar
John Holloway
John Holloway is offline
86 F 150 sat for years
Me and my dad were trying to start his old 86 F 150 a while back. We put starter fluid in it and it turned over. I put it in drive and it moved a foot then acted like it wasn't getting gas. I'm new to this and I just really need some help so I can get this thing running any idea?
Old 03-26-2017, 11:40 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,104 Likes on 1,792 Posts
John, Welcome to FTE.
First we need a little more information.
We know it is a 86 and a F150
Motor size? is it stock or any mods done to it?
1 fuel tank or 2? If 2 what happens when you flip the switch?
Did you drain all the old gas out of the tank(s) first before trying to start the truck?
Why was the truck parked for so long?
Let try that for a start and then we can move on to checking things like spark, fuel PSI etc.
Dave ----
Old 03-26-2017, 11:36 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Or your ECA is keeping it turned on ............
What engine do you have ? 302 I would say...
http://www.garysgaragemahal.com/elec...p-control.html
See page 106 for Relay location,,
Joseph Hughes
New Member Introductions
10-09-2017 03:29 PM
tombob
08-23-2017 07:45 PM
86barnfind
13
03-25-2017 04:51 PM
gonzales
1997 - 2003 F150
16
01-06-2017 09:25 AM
crandallf150
12-03-2016 08:48 PM
Quick Reply: 1986 F150 Fuel Pump Relay Location
