Welding body panels
Not being the best welder, I used a lap joint. But before tacking the patches, I trimmed the recessed sections down to where there was less than 1/8" of surface for the patch to rest on. I also used weld thru primer and two types of sealer on the inside. FYI, I bought a $20 panel flanger from Harbor Freight (Central Pneumatic) and it worked great.
in my oppionion the butt weld is the best , the flange is ok IF you use weld thru primer and seal all the areas that can wick moisture . I have seen panels that have been replaced using a flange (sp late and tired) and rust was a problem between the two . so if there butt welded that cant happen.
just my .02
just my .02
1982fordf100
11-13-2005 08:20 PM
1982fordf100
04-14-2005 02:50 AM
1982fordf100
11-30-2003 10:37 AM
