Oil pressure low at idle - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-14-2004, 07:19 PM
mstepchinski mstepchinski is offline
mstepchinski is starting off with a positive reputation.
Hi -
I had someone pull off my oil pan to reseal it, and since he put it back on, the oil pressure bottoms out at idle, then goes up and down. At speeds above idle, the oil pressure is fine. We have already replaced the oil pump hoping to resolve the problem, but the problem remains. I did not have any oil pressure issues before he took the pan off.
My truck is a 94.5 PSD.
Anyone seen this before??
Thanks in advance!
Mike
Old 09-14-2004, 08:05 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Have you checked the oil pressure with a test gauge? A piece of grit from the gasket replacement may have found it's way into the sending unit. If the oil pressure is actually low, it may be from a split in the pick-up tube or a poor seal where it attaches.
Old 09-14-2004, 08:13 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Quote:
Or gunk in the pick-up screen itself.
Old 09-16-2004, 10:22 PM
Thanks for the input. THe guy working on my truck called and told me that the front over (houses the oil pump, HPOP, pickup tube) had a crack in it. I am wondering if he cracked it when removing my pan, but I have no way to prove. The front cover is about $200.00 - does this sound right? Also, why would oil pressure drop if there was a crack? Would oil be leaking back down into the pan? There was no oil leaking back outside the enging, accroding to him.
Anyway - thanks again for your input!
Old 09-17-2004, 05:02 AM
You lose oil pressure because the tube is on the suction side of the oil pump, and with the crack it draws both air and oil. Less oil, less oil pressure. Depending on the location of the split, sometimes you can overfill the crankcase with oil and regain oil pressure. This is to assist with diagnostics and not recommended for normal operation.
What causes low oil pressure? Number21 6.0L Power Stroke Diesel 25 05-14-2014 04:52 PM
shaky oil presure OldFords Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 17 06-04-2007 04:03 AM
overfilled oil level 5.0L Ranger GT2 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 04-03-2007 03:57 PM
99 4x4 5.4 intermittent oil pressure briansc99exp Expedition & Navigator 2 07-16-2006 10:14 AM
390 No oil pressure? wiznewski FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 06-25-2006 08:55 PM
Tags
2000, 73, 73l, diesel, drop, expedition, ford, idle, location, low, oil, power, pressure, psd, sending, stroke, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
