Where is my Temp sending unit? - Ford Truck Enthusiasts Forums
Old 09-14-2004, 11:01 AM
thundrrod thundrrod is offline
thundrrod is starting off with a positive reputation.
Exclamation Where is my Temp sending unit?
I have a 99 F150 4.2 liter. temp gage show redline but engine is not over heated. let it run in my garage for 20 min in the red and then I shut her off and turned her back on; gauge went to normal position. fuses look good. I cant seem to locate my temp sending unit though. there is a plug to the right of my thermostat housing but can locate where the unit is!!!!
Old 09-14-2004, 12:07 PM
lardman lardman is offline
lardman is starting off with a positive reputation.
I looked in a service manual and only saw a temperature sending unit on the 4.6L...it is located on the front of intake on the right hand side.
The 4.2L has a head temperature sensor on the rear of the left hand head. I am sure someone else will be of more help.
Old 09-14-2004, 12:09 PM
would that be rear driverside head? thanks for the quick response!!
Old 09-14-2004, 12:23 PM
Yes. When considering vehicle handedness, always think of it as you are sitting in the vehicle. i.e. left hand = driver's side. Not sure if it is the sensor that ties to your light/gauge.
Old 09-14-2004, 12:47 PM
thanks!! will keep looking!
Old 09-15-2004, 12:30 PM
Little help
Does anyone have a pic on where the temp send unit is on my '99 4.2L F150? thanks !
Old 09-15-2004, 08:51 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
It's on the intake manifold, close to the thermostat.
Old 09-16-2004, 09:40 PM
Thanks! man Really appriciate it!! checked it out but my actual problem was a stuffed up radiator. got it flushed, and all that good stuff. my baby is cool as a breeze now! thanks!
391 Temp sensor location 351bolt Large Truck 2 04-20-2015 04:35 PM
where is the water temperature sending unit? 1978fordf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 09-07-2010 10:52 PM
Oil Temp sending unit Hiflyer746 1999 - 2003 7.3L Power Stroke Diesel 10 11-18-2006 02:45 PM
Temperature Sending Unit Flood Cooling, Heating, Ventilation & A/C 5 04-18-2004 09:37 PM
Temp sending unit location cw50must Ford Inline Six, 200, 250, 4.9L / 300 7 05-21-2002 10:26 PM
Tags
1999, 2003, 42, 46, expedition, f150, ford, head, location, sender, sending, temp, temperature, unit, units
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
