Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-11-2004, 10:38 AM
spiked spiked is offline
Garage is empty, add now
spiked is starting off with a positive reputation.
#1 cylinder
i need to know what piston is the #1 cylinder so i can time it on a 1968 534 in a T850 dump truck i just purchased ?? it has all new ignition and it runs like it is laboring all the time?? also need to know what the timing specs are ???
any help would be greatly appreciated !!!
  #2 (permalink)
Old 09-11-2004, 05:04 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Driver side front is my guess. Look on the runners of the intake manifold...sometimes the numbers are cast on those.
If you go off the Driver side front vs. pass side front, your timing light should tell you if you are close, and then you can adjust from there.
  #3 (permalink)
Old 09-13-2004, 01:01 AM
f250rangerexplorer's Avatar
f250rangerexplorer f250rangerexplorer is offline
1981 GMC Sierra 3500
f250rangerexplorer is gaining momentum as a positive member of FTE.
i always thought on v-8's that they were as looking towards the rear.
1-3-5-7 Pass Side
Intake
2-4-6-8 Driver Side
Maybe i'm wrong but just my $0.02
1978 F-250 Ranger Explorer 4x4
351M, C6, Np205, D44, D60 4.10LS
Drive It Like You Stole It!!!
__________________
-Aaron
2005 F-350 Lariat, CCLB DRW 6.0l, 5R110, Fx4, 4.10's 199k
4" TBE w/kitty, 285/70r17's, 3" Lift Kit, B&W Gooseneck Hitch, Studs soon to come.
1999 F-350 Lariat, ECLB DRW 6.8l, 4R100, 4x4, 4.30's 129k
285/75R16's, 2.5" Level Kit, Gooseneck and All Stock
  #4 (permalink)
Old 09-21-2004, 10:45 PM
Birken Vogt Birken Vogt is offline
Birken Vogt is starting off with a positive reputation.
I had one heck of a time re-ordering the wires on one that someone had screwed up the order on, I could not for the life of me figure out the cylinder numbering. I had to take off the valve covers and take out the spark plugs and put bits of solder in the holes and then have someone bump the starter so I could see which order things were working in. This is what I came up with:
Code:
Driver    Passenger
The reason I had such a hard time with it was that I had always been taught that the forward most cylinder was number 1, not so in this case.
Birken
  #5 (permalink)
Old 09-22-2004, 03:14 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
#1 should be the front passenger side....
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #6 (permalink)
Old 09-22-2004, 09:47 AM
thanks for all the help !!!!
Tags
1, 1977, 460, cylinder, ford, number, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
