You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
hello have a 1984 class C rv would a gear vender under/overdrive improve hills and mountain driving on this 3 speed HD diesel rv is listed as a 1985 model moter is 6.9L
Well, I had replied last night, and now it's gone... Oh well, I will do it again. The overdrive/uderdrive should make quite a difference, as it will give you overdrive for regular cruise, and will give you more gears to pull the hills, likely you have been able to guess that the 3 speed could use some gears in between the ones it has. You could get by on the cheaper unit if you aren't planning on towing, or at least not towing heavy.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
__________________
