air conditioner won't switch correctly
hey all, last week i turned my air con on and it took a while but it finally started blowing out the normal vents. but for a while it only blew through the defroster vents. and it was cool so the compressor was working. today, i drove around for an hour and it only blew through the defroster vents ONLY!
is this a fuse or relay issue? thx yall--jw
i have a 98 explorer XLT.
Water control valve
Originally Posted by jwford
Look to see if the vacuum line fell off the water control valve
hey homer, where is the water control valve?
Could be a couple of things..
thanks gearz, nope---no hoses disconnected. what exactly is the "blend door"? i'm still having the problem. i don't wanna take off the inside controls cover if it's not gonna help...! anyway, still stuck..
Hello All,
I had this exact problem. Temp control worked, but air (hot, cold, ac, no ac, didn't matter) only came out of the defroster and foot wells. This thread led me in the right direction. It was a vacuum leak.
Here's a little more detail that might help troubleshoot. This is for my '97 Explorer XLT, you're locations may be different, but should be basically the same. This may be a little elementary for some, but until I started researching and looking under the hood, I had no idea where to start.
The vacumm starts at the engine (drivers side, valve cover). It splits and part goes to the emision system (front, drivers side) and part goes around the back of the valve cover. On the right side of the valve cover, it splits again and part goes to, not sure what it is (this component has an electrical connection and a braided line coming in and is near the front of the engine, passenger side), but it doesn't matter, it is the other branch that we care about. The other branch goes to the vacuum resevoir tank (about the size of a black softball) for the ac.
This is where I started. It's not that hard to get to. Crawl under the front corner just below the air filter and remove two screws (9 mm) that hold on the front of the plastic wheel well. Two more (11 or 12mm?) hold on the tank. I didn't need to remove it though as I could pull the wheel well down far enough to get to it. One line goes in and one line goes out and up to the firewall under the heater core. Anyway, I disconnected the line coming from the engine and, with the engine running, I checked for vacuum. It was good and strong. I could feel it with my finger, but put a gage on it anyway and it read normal. Reconnected that and was following the line coming out and going to the firewall to find a good place to disconnect and check it, when, Eureka!, the line was broken in half. It was broken halfway to the firewall, underneath a bunch of stuff where I couldn't see it. So, my problem was before it got to the firewall.
A few additional comments for greenhorns like me if you have checked this far and haven't found your leak yet:
That line (going to the firewall from the resevoir tank) goes into the firewall via a connector that comes in right under the glovebox in the corner (easy to see). It comes in and goes through the control system and back out through the firewall at the same connector (there are two lines at the firewall connector, one coming in and one going out).
I would start either at the connector at the firewall (black line, I think) or at the resevoir tank as they are much easier to get to than the lines up near the controls. You might as well make sure that you have a vacuum at the firewall before taking the dash apart.
Good luck! I know it's going to be nice going to work tomorrow without my windshield frosting up from blowing my AC on it
3006ROCKS
22
01-21-2018 02:49 PM
jennshusbum
07-26-2014 10:07 AM
