Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-10-2004, 01:32 PM
Pakrat Pakrat is offline
Garage is empty, add now
Pakrat is starting off with a positive reputation.
37 60hp waterpumps
This is the first time I have owned a vintage automobile, so I am new to the 60hp engine, hence my ignorance. This is the setup which consists of two water pumps held in the front of the engine by large spanner nuts. fficeffice" />>>
Are the impellers lubed by the water or oil seapage from the bushing chamber? Noticed that the groove in the main housing on the front of the engine between the two leather/cork o rings has a hole in it filled with oil sludge, is this an oil passage of some kind to lube the bushing and impeller, or just a vent connected to the crankcase?>>
If the impeller is water lubed should i assemble it without grease on the impeller or maybe water soluable grease. what does ford say?
Is there a good website for original ford TO's [instructions] for parts overhauls.>>
Thanks Mike
Tags
60hp, flathead, ford, pump, pumps, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
