Lubrication points - Ford Truck Enthusiasts Forums
Lubrication points
Old 09-10-2004, 12:02 PM
Wolfdog Wolfdog is offline
Wolfdog is starting off with a positive reputation.
Lubrication points
my 2005 F-150 Screw Lariat has now about 8000miles. I was wondering what parts need to be lubricated with a grease gun (do you called it a grease gun in English -- I'm orginally from Finland so my English is...what it is).
Great truck -- all my family and 4 dogs fit in well and still room for a lot of stuff...
Thanks for advice.
Old 09-10-2004, 05:25 PM
mwh mwh is offline
mwh is starting off with a positive reputation.
WOLFDOG-- Ford truck front suspensions are supposed to be sealed, and therefore do not have zerks (grease fittings for the grease guns). There is no way to grease the joints or moving parts on Fords. But, there is always the possibility there might be (1) or (2) zerks on some models on a certain steering arm or other place. Ask your dealer about this or make a good visual inspection, if you don't see any zerks you don't need your grease gun because it was lubricated at the factory and then sealed.
Old 09-11-2004, 03:15 AM
Thanks a lot.
I will have a closer look. I owned a GMC Yukon (1998) and the Workshop manual showed several lubrication points...that's why I asked this question
But I guess one can't compare a Yukon to F-150...
Universal joint lubrication j66b 1997 - 2003 F150 17 10-05-2014 07:57 PM
Window regulator lubricant tip49 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 05-05-2010 11:38 AM
How do you lubricate U joints on Driveshaft Hometown Pride 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 06-28-2009 10:28 AM
Lubrication Points???? PAPPYBALL 1997-2006 Expedition & Navigator 6 10-29-2006 08:16 PM
Upper Kingpin Won't Take Grease--What to do? TallPaul Brakes, Steering, Suspension, Tires, & Wheels 6 07-31-2006 07:45 AM
Tags
05, 2004, 2005, 2007, 2008, 96, expedition, explorer, f150, ford, grease, greasing, lube, lubrication, points
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
