1987 Ranger 2.3L gas mileage - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-08-2004, 08:14 PM
87 stranger 87 stranger is offline
87 stranger is starting off with a positive reputation.
Question 1987 Ranger 2.3L gas mileage
Hello everyone, what kind of mileage should I expect from my 87' ranger? My Ranger has a fuel injected 2.3L engine, 5 speed manual trans, and a 3.45 gear ratio rearend. This is a standard cab 7 foot bed truck that is 2 wheel drive. Any information from experience is appreciated. Thanks
Old 09-08-2004, 10:28 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
Depends on how well it has been maintained and how many miles are on it.
Old 09-08-2004, 11:25 PM
The odometer in my truck reads 48,167. I don't know if that is the original mileage or if it is 148,167, I assume the latter for it's age. The engine doesn't smoke or use oil. It's recently had a complete tune up by myself at my shop/garage. Thanks " el c"
Old 09-09-2004, 12:35 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
i have an 87, but its extended cab, 2.3, 5 gear, and 3.73's in tip top condition. i get 18-21 depending how and where i drive it (doesn't really care for hills) the biggest killer that i found is when your pushing it dont give it more throttle than it can take, more throttle=less vacuem=higher fuel pressure=poorer gas mileage
Old 09-09-2004, 01:57 PM
G2IC_Wraith G2IC_Wraith is offline
G2IC_Wraith is starting off with a positive reputation.
As far as MPG, mine has seen a wide range. I have a similar truck, 88' 2.3L, 5sp, x-cab, ??? rear end (I know it is 7.5"). When I first got the truck about 1yr ago it was only getting 17MPG avg. After many std service repairs, plus a new trans, new tank, fuel filter, and too much to list it runs great. Some stuff covered here: (cleaning the TB and intake was a big help)
http://www.ford-trucks.com/forums/sh...d.php?t=248941
Now I get MUCH better MPG. I only drive 10 miles to work, so it is mostly city/stop-n-go driving. 23-25MPG city, 25-27MPG hwy. Oh, I forgot to mention.... 115k.
Old 09-09-2004, 08:31 PM
Thumbs up
Wow, thanks very much for the information to all. Looks like I have some reading to do from your link G2IC_Wraith. I will definitely read this and see what I can come up with on my Ranger. I'm getting ready to do a tune up on it this weekend. Again, thanks very much for the replies and the help.
Need Pro Techs HELP Please....(LONG) lorenambrose 3.0L V6 11 06-26-2010 07:53 AM
2003 Ranger 2.3L - Pic of vacuum port wanted Timbo1985F150 Ranger & B-Series 0 02-02-2009 09:18 AM
98 turbo 2.3l 278hp ranger????? htech06 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 8 10-06-2007 06:39 PM
invoice 06 ranger mackman107 Car/truck Buying Advice 2 09-18-2006 05:39 PM
Ranger engine swap Jippah Ranger & B-Series 6 08-31-2005 06:20 AM
Tags
1987, 23, fuel, gas, mileage, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
