Fuel Pump Air Lock??
Trying to start my overhauled 55 Y block. New fuel pump and all lines. Gas tank cleaned and coated. Filled glass bowl on the fuel pump and carb float bowl. Engine will run until carb float bowl runs dry then stops. Fuel pump is not working. My thought is it is air locked? Any suggestions will be much appreciated.
Fred K.
Fred K.
Fred - I don't have a Y-block, but believe that the setup is basically the same on all Ford engines.
I would check and make sure that the fuel pump is installed correctly with the pickup arm under the cam lobe. These sometimes get installed inadvertantly with the arm above the lobe and there is no actuation of the pump. Simple to check/fix.
Think I have found the problem. The pickup tube inside the tank is blocked with something preventing the fuel pump from sucking the gas. Tried to push a wire down it but no soap. Will have to take the tank off. Damn! Apparently the Rad shop that cleaned and coated the tank must have blocked the tube with the coating. Thanks for the replies.
Fred K.
Fred K.
I need to get a new fule pump for a 1050 F1, they said that the original cept getting gumed up so they put in an electric pump, neither work now, what pump should I get, I went into several parts shops and they said they can't get pumps for trucks that old.
I had another thread on this but I can't find it now.
any help
any help
is there an advantave to using a electric pump over the original.
the old owner said that he switched to an electric pump because the original kept getting gummed up and he got sick of cleaning it out.
which pump would be better to put in-I need to buy a new one either way and I just want to get what would be best and I don't want to work on the fuel pump every time I fill the tank.
I've run a mechanical pump for over 3 years without missing a beat. They are dependable. I suspect the previous owner of your truck also gummed up the electric pump with the same crap that was getting sucked into the mechanical pump because he didn't take time to clean the gas tank and old lines!
Take out the tank and get it cleaned at a radiator shop and replace all the steel lines to the pump. Install (as suggested) an inline filter and you won't have a problem with a stock pump. I got mine at Sacramento Vintage Ford. NAPA should carry them also or can get them easily. Have the computer jockey behind the counter dig out the obsolete books on the shelf below the 'puter and look up the number he/she needs to order.
The only hitch with the stock pump is the diaphram can rupture with age and then dumps gas into the crank case. Regular maintenance issue. If it doesn't pump, sniff the dipstick for gas odors and an over-full condition.
Ar. Hillbilly
18
11-16-2016 08:16 PM
jvmcc
10-02-2016 08:05 PM
Scott Yager
28
05-29-2016 08:21 PM
