Confussed on mileage changes, HELP!!!!!!
I have a '04 F250 FXA Lariat LB. It has 12,756 on miles and I have had two oil changes.
Question: I was getting 15.5 to 15.6 miles to the gallon prior to my first oil change. After first oil change mileage went to 15.4 to 15.5 miles to the gallon til my second oil change. After my second oil change the mileage went to 15.3 to 15.4. Then I pulled my fifth wheel for 500 miles and after the trip was over I was getting 15.1 miles to the gallon. I am still getting 15.1 miles to the gallon empty after two fill-ups. Am I just crazy or is there possibly something going wrong?
Also, would a fuel conditioner possibly help? IF so what type and brand??
Silly me...
but have to ask the usual questions...
are you resetting your overhead ?
Have you reset the overhead anytime ?
how are you calculating your mpg ?
are you filling it up until it overflows to the same level each time ?
SO many variables... .4 mpg is almost too close a tolerance to measure....
I am using actual miles driven divided by the amount of gallons put in the tank. ie.. miles at last fill-up subtracted from current miles at next fill-up divided by gallons put in tank at current fill-up.
What did you mean by "resetting the overhead"???
I am filling up til the first shut-off everytime.
on
What's the weather been like throughout the history of the truck? I'd expect some change from winter to summer just because there's less O2 in the air on the hotter days.
It could easily go the other way too in the winter I'd think, because you might tend to let the truck idle more before driving.
Tire wear and tire pressure could be a factor as could traffic. Pretty tough to nail thinks down to a tenth of a MPG I'd think. . .
on
Speaking of Hades, my mom is out here visiting because of the new baby. It has been so hot here in San Diego that she's calling to see if she can change her flight to go home to Nebraska early.
They have AC at home and we don't here at our house. It's 86 deg and 65% humidity right now. Rather balmy I think, but too hot for her . . .
