Orderer new 2005 - 4.10 or 3.73 rear end?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-07-2004, 03:19 PM
superv10's Avatar
superv10 superv10 is offline
superv10 is starting off with a positive reputation.
Question Orderer new 2005 - 4.10 or 3.73 rear end??
I'm orderering a new 6.0 with auto trans - should I get the 4.10 rear end or go with the 3.73. I plan on doing about 1/4 of the time towning - boat in summer, snowmobile trailer in winter.
I know the 4.10 will give me much better pulling power, but am I going to notice a big mileage drop for all those times I'm not pulling anything??? I currently have a V10 with 3.73 and that was a big mistake - can't tow anything, but the new 6.0 with Torqshift has so much more power can I get away with the 3.73 towing???
Thanks all you PSD owners!! Ready to become one!!
-superv10
Old 09-07-2004, 03:29 PM
basstardo's Avatar
basstardo basstardo is offline
basstardo is starting off with a positive reputation.
If you're gettin a PSD, the only way you're gettin anything beside the 3.73 is with a dually. The 3.73 is plenty with the 6.0. I have the 7.3 with 3.73 and I have zero problems pulling.
Old 09-07-2004, 03:41 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
Quote:
yea, i thought the same thing. 4.10's are only available on the dually's
Old 09-07-2004, 03:45 PM
superv10's Avatar
Actually no - just talked with my dealer yesterday - ford changed the options, you can now order a 4.10 rear end on PSD with F350 SRW (single rear wheel)..
I thought the same thing up until yesterday when we went thru the ordering options..
Old 09-07-2004, 04:14 PM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Get the 4.10, that's why they opened up the option. Way too many people wanting just a little lower gear.
But, that could have been the heat coming from the 4WD owners.
Old 09-07-2004, 04:17 PM
wlihntr's Avatar
thats cool, i think its a good move on fords part to offer that. i would go with the 4.10's as well ( i,m all about more power) especially if you plan on putting on a little bigger tires down the road.
Old 09-07-2004, 04:52 PM
superv10's Avatar
Great!! I do plan on going slightly larger then the stock tires so I think I will go with the 4.10's....4.10 and a Predator will definately allow me to drag race and smoke rice burners while towing 10,000 lbs!!!!!!!!! Man, I can't wait!!!
Will have to change from superv10 to superPSD.!
Old 09-07-2004, 06:14 PM
Big Orn's Avatar
Just leave it. You'll have that V10 look about you. You might need it in a pinch...
Old 09-07-2004, 06:45 PM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
PSD in a SRW 4x4 with 4.10 gears... Man that sounds like a great combo! Glad Ford finally saw the light .
Old 09-07-2004, 09:47 PM
mulelady mulelady is offline
mulelady is starting off with a positive reputation.
superv10: it sounds like you're set on the 4.10....but wanted to let those that care....we've been hauling a three-horse slant trailer up and down the Va. mountains to Tenn. with plenty of power. We have the 3.73 in our '02 because the truck spends most of its hours not pulling and we wanted the benefit of better mileage. From what we hear....we'll be doing even better when our '05 arrives. Mulelady
Old 09-08-2004, 01:13 AM
frydaddy56 frydaddy56 is offline
frydaddy56 is starting off with a positive reputation.
we have the 2004 V10 with 3.73 gears pulling a 10,000 fifth wheel with no problem goes down the road at 70 plus if i want in overdrive.Don't understand why you are saying V10 with 3.73 can't pull anything??????? Just my 2 cents FRYDADDY56
Old 09-08-2004, 01:58 AM
superv10's Avatar
It didn't tow bad when I had stock tires on it - fuel mileage was horrendus (sp?) 7mpg... But now that I have "normal" size tires on a big Ford truck (265x75R16's are for wimpy chevy tahoes...) towing above 65 requires my foot being shoved thru the firewall... Of course, I'm out here in the west and we tow toys at high elevations - sometimes over 8,000 ft - which makes a difference...
Old 09-08-2004, 10:02 AM
basstardo's Avatar
Quote:
You ain't kiddin! If my truck had 4.10's right now, I wouldn't even be worrying about regearing the dang thing...
Guess it's gettin closer to time to trade in...
Old 09-08-2004, 11:04 AM
BenW84 BenW84 is offline
BenW84 is starting off with a positive reputation.
I would go with the 4.10s or 4.30s I have a 04 cc with the 5.4 6 speed with 4.10s and I love it. When I go to bigger tires I wont have to regear.
Old 09-08-2004, 05:13 PM
Loyd Lucas Loyd Lucas is offline
Loyd Lucas is starting off with a positive reputation.
With 4.10's do you think you're gonna go up a 6% grade in high gear with tall tires? Dream on! That's what they have gears in the transmission for.
F-150 ecoboost 3:73 vs 4:10 rear diff bsbllrooster 2009 - 2014 F150 3 06-20-2011 08:24 PM
3.73 or 4.10 jerg_064 Clutch, Transmission, Differential, Axle & Transfer Case 10 01-18-2008 10:02 PM
ordering my '05 f350 chevy_20 6.0L Power Stroke Diesel 7 01-05-2005 12:51 PM
3.73 or 4.10? dcbollinger 6.0L Power Stroke Diesel 1 05-26-2004 02:01 PM
3.73 or 4.30 Rear FordRancher 1999 to 2016 Super Duty 55 12-22-2001 02:21 AM
Tags
373, 410, end, f250, ford, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
