Anybody have a dashboard rattle?
I've got a pretty bad dash rattle that I can't pinpoint. Seems like it's below the radio at one point, then under the passenger seat at another point. May be related to water since it happened the first time after leaving a drive-thru car wash (for about 10 mins). Just drove 4 hours in the rain and it was on and off, mostly on.
Occurs at highway speed.
Fx4, one month, 1600 miles, and for those that listen to Car Talk, it's Dark Shadow Gray.
ok not sure if this applies to you........ but i was going on a long trip and i noticed a little rattle. i figured it was something in the cup holders so i cleaned it out. then i went for the change holder in the center console....cleaned that out also. no such luck. i had the a/c on and was starting to get chilly so i moved the vent in a different direction...and the noise went away. moved the vent back to where it was and sure enough the noise came back........so i would try moving your vent on the dash (either close it or change the direction of the fins) and see what happens. it worked for me. mine was the one on the left side of the radio. good luck
I found what I thought was a dash squeek (and sometimes a rattle) to be the black plastic window trim below the wipers. This is that big long black plastic piece with the ridges, outside of the window, just below the wipers. It was rubbing/rattling against the window. I haven't found a way to get those cheezy fasteners to hold it where it should be.
Mine squeeks like crazy - sounds like rubbing two pices of a styrofoam cooler together, or hard plastic rubbing together. It will get quite loud for a while, then quit for a while. I'm chasing it around but can't pinpoint either... Sounds like it originates real close to the winshield wipers and right in the center though.
my 2004 supercrew has only 200 miles on it so far, and is kind of driving me nuts with the styrofoam squeek. I can't figure out if it's a hot/cold condition thing, but I do know that if I push on the dash hard with my right hand, all noise stops.
Funny coincidence is - when I test drove this truck at the dealer, the stock 6-disk stereo was dead. Sales guy says that plugging it in is part of the dealer's prep after they recieve the truck from Ford and they must have forgot. They had it working before I left with the truck. I almost wonder if the maintenance guy smashed or left something behind in there...
I'm pulling the stock 6-disc to replace with a kenwood setup this weekend, and am installing Prodigy trailer brake controller, so I plan to do some real looking around in there for the source...
Pushing just to the right of the steering wheel, just above the round a/c vent, right where the dash rounds over from vertical to horizontal. Seems like the dash is made from two different types of plastic, maybe it is the joint between the two that is rubbing. I still think there is some styrofoam in there.
Rattle gone. Don't really know why, but I took the radio trim panel off to put in a Kenwood reciever, put it back together carefully and tightly and rattle is gone.
With the factory 6-disc out (which is very easy to remove) there is a ton of space in there to look around at all of the dashboard joints. There are pads all over the place and I see that many rattles and squeeks could be different, but getting in there with some more adhesive foam pads to spot fix a few is a great idea...
rattle or squeek
Mine f150 started to make a noise from the tray above the radio. only at night, or when it's cooler. if you place your hand on the tray (as a passenger, of course) the sound goes away. I had thought it came from the drink holder or radio, but it's that darn tray.
Chris
250 mile on it, and so far 13 mpg. OUCH. what about the 15 mpg epa? I usually get one to three more than EPA. Not on this beast.
Chris
